I am wanting to run my rc10 with a 8.4 volt (7cell) NIMH battery pack and was thinking about buying a XPS micro esc #8023AE to go with it. Will this combination work? I read where I CAN NOT use the diodes described in the rc10 build manual to reduce the voltage, is this correct and if so will the esc handle the higher voltage? I don't want to ruin anything with too much voltage.
Thanks, Jack
XPS micro esc #8023AE and 8.4v battery pack?
- Has thanked: 100 times
- Been thanked: 205 times
Re: XPS micro esc #8023AE and 8.4v battery pack?
I think that speed control is not what you are after for a 10th scale car as that is the stock speed control for a RC18t/b/mt If you want a speed control in that same basic size/shape you may want to look at one of LRP's speed controls like the AI runner... except that only is specced to 6 cell. Hmm. Well the main part of this post is the speed control you have selected will go up in smoke in your planned setup
Chris
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- 5226 Views
Last post by mk-Zero
- 497 Views
- 469 Views
Last post by GreenBar0n
- 1381 Views
Last post by esaresky75
- 6140 Views
Last post by NomadRacer
- 1149 Views
Last post by integra22t
- 2005 Views
Last post by slotcarrod
- 800 Views
