Outdrive help needed
General info, Q&A.
shodog
Been thanked: 91 times
Post by shodog »
What is the difference between outdrives for a B2 transmission and out drives for a first generation stealth like those found on the CE, RC10T and DS?
I have a set of MIP light drives I would like to use on an upcoming build.
templeofspeed
Been thanked: 33 times
Re: Outdrive help needed
Post by templeofspeed »
B2 is larger in diameter than the 2.25 and smaller than the 2.60. B2, B3 and T3 are the same.
mikedealer
Post by mikedealer »
i believe the b2 outdrives will work with the correct diff rings inside the original 2.25 but i could be wrong
shodog
Post by shodog »
The dives come with the diff rings, I guess I just need to see if the diff rings will line up with the balls and fit insed the main gear.
aconsola
Post by aconsola »
templeofspeed wrote:B2 is larger in diameter than the 2.25 and smaller than the 2.60. B2, B3 and T3 are the same.
Shouldn't that be T2,B3,t3, and GT?
b2, b3, and t3 are the same. 2.40
t2 and gt are the same. 2.60
aconsola
Post by aconsola »
I should have known better than to doubt temple, but for some reason thought that the GT was the same as the t2/3.
I had it halfway :D
