Light Weight Outdrive on T3
broodenburg
Has thanked: 35 times
Been thanked: 10 times
Post by broodenburg »
anyone knows if the Factory Team Light Weight Outdrive Set [ASC1766] fitt's a T3/B3?
And if so; does that makes sense or should I just use the standard version (or perhaps the thunder tiger version..)
thanx
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: Light Weight Outdrive on T3
Post by RC10th »
No they wont fit unfortunately. Associated #1766 are for a 2.6:1 transmission and the B2/B3/T3 are 2.4:1. From information that I can gather on ring sizes the 2.6 rings are 17mm ID / 23mm OD, the 2.4 rings are 13.4mm ID / 21mm OD.
broodenburg
pitty...
but thanx for your reaction!
Return to “RC10 Truck Forum”
