Finished mid/late Edinger
- marlo
- Has thanked: 18 times
- Been thanked: 22 times
Hey, finished my mid/late Edinger posted in my gallery but thought I'd show more pics here in case anyone had any questions or wanted to comment. Thanks for looking. BTW the only thing that is not original with this build, or any of my builds, are the SS ball studs, I do have the originals in the kit box, I always swap them out for my builds, just so rust won't stain my parts.
- Has thanked: 1130 times
- Been thanked: 3920 times
Re: Finished mid/late Edinger
That looks great Marlo! I think a lot of people put too much emphasis into a super clean chassis and ultra bright parts. It's great to see the original unmolested colors and imperfect chassis finish because that's exactly how they came out of the box. Looks awesome!
Hey, where's the sway bar
your not done yet sir!
- marlo
Soldering them was always a pita, even now I'm great with an iron and they make me look bad!
- ChisaiKuso
- Has thanked: 5 times
- Been thanked: 27 times
x2gomachv wrote:That looks great Marlo! I think a lot of people put too much emphasis into a super clean chassis and ultra bright parts. It's great to see the original unmolested colors and imperfect chassis finish because that's exactly how they came out of the box. Looks awesome!![]()
I don't whiten any of the nylon parts on my builds, and I love it when the anodized parts are flawed and/or don't match each other. This car looks awesome!
Something clever goes here...
- Has thanked: 36 times
- Been thanked: 1319 times
what do you use for the stainless steel tie rod balls? part number or vendor?
build looks super as a 'real' original build, as mentioned!
- marlo
Yah, I did have a hard time on that, I searched around, looked at some other builds, the manual does show it to be the way you mentioned, I'll get on thatscr8p wrote:Looks good.
Now flip those front shock rod ends around.
The reason for the upper rear being opposite of the newer cars is because you can't move the arm mount forward. The shock cap would bind up if you flip it around.
I usually ad a spacer down at the arm on older cars so the shock is straight and moves freely.
- marlo
Thank you very much for the compliment. For the ball studs, I use AE #6273 (long), comes in kits of two studs, and #6271 ball stud set, 12 short in that set, the threads on some do not go all the way up the stud, I pick the best one's, and run a 4-40 tap in all parts, and when room permits, I give the hole a light counter sink to clear any unthreaded part of the stud.jwscab wrote:what do you use for the stainless steel tie rod balls? part number or vendor?
- ChisaiKuso
I would suggest building it like the instructions show for that particular model. Associated changed the order and orientation of the nuts, washers, and bushings quite a few times over the lifespan of the RC10. Some of the early build instructions don't make a lot of sense from a logical point of view, but it's neat to see the cars as they would have been put together at that time.marlo wrote:another thing that also got me was the top rear shock bushing, I placed them as I would on later cars, but in the manual its backwards, any thoughts
I learned that bitd, that's why all the servo savers are cracked now. If you don't chamfer the hole it splits over time.marlo wrote:I give the hole a light counter sink to clear any unthreaded part of the stud.
- marlo
I also do not tighten the studs right downgomachv wrote:I learned that bitd, that's why all the servo savers are cracked now. If you don't chamfer the hole it splits over time.marlo wrote:I give the hole a light counter sink to clear any unthreaded part of the stud.
Thanks Marlo, good to know! I didn't even realize those were stainless. And yes, it's correct to account for the unfinished threaded portion with either a washer, spacer or countersink the hole to prevent undue stress.
- 31 Replies
- 3644 Views
Last post by Diggley
- 36 Replies
- 3569 Views
Last post by THEYTOOKMYTHUMB
- 1243 Views
Last post by LurkingCAT
- 701 Views
Last post by CamplinP
- 1219 Views
Last post by yellowdatsun
- 32 Replies
- 3624 Views
Last post by lowrydesign
- 1285 Views
Last post by adam lancia
Users browsing this forum: Mojeek [Bot],
Yandex [Bot] and 4 guests
