Ofna 19034 hingepins on YZ-10/870C ?
lifeIsAnalog
Post by lifeIsAnalog »
Has anyone tried the Ofna 3x40mm hinge pins (p/n 19034) as replacements for the YZ-10 rear suspension arm pins? Mine are bent and now have teeth marks on them (the pliers, not mine).
They are a little longer than stock (40 vs 38.5mm) which is not a problem. I am more concerned about the diameter. On paper they should work, but I trust word of mouth confirmation a bit more :)
Romans 5:8
lifeIsAnalog
Re: Ofna 19034 hingepins on YZ-10/870C ?
I'm almost convinced that the Ofna pins will not work.
I tried the hinge pins from my Traxxas Bullet. Length is perfect, but at 3mm diameter, they won't fit. So the YZ-10 pins are smaller in diameter (~2.5mm by my measurements).
Has anyone found suitable replacement YZ-10 rear suspension arm pins?
Romans 5:8
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
The Touring car pins fits.
Yr-4
Gone fishing
lifeIsAnalog
Good info, DennisM. I'll check it out today. A quick search only turned up one set, on eebaye. Made of titanium, so they're priced accordingly, but I'll keep that in my back pocket. I will also look at aftermarket.
Romans 5:8
Justjoe
Post by Justjoe »
check this link. the Ofna pins i used fit and there are pics so you can see how they fit.
http://www.rc10talk.com/viewtopic.php?f=29&t=16827
USAF Retired
870C, Works 91, YR4-M2 Pro, RC10 Graphite, RC10 Carbon fiber tub
Old Skool RC10 Gold pan, RC10DS, Traxxas REVO
lifeIsAnalog
Set ordered! Even though they are a bit long, I can't complain at that price. Thanks Justjoe and DennisM for the tips! I like the turnbuckle idea Justjoe.
Romans 5:8
lifeIsAnalog
The Ofna 36170 pins arrive, and although a bit long (as expected), the diameter is perfect! Thanks again. Apparently 3mm is not 3mm with all manufacturers. Must be like shirt or trouser sizes :)
The rebuild continues...
Romans 5:8
Return to “Yokomo Forum”
