Holes in pan
mick355
Help to ID please
Post by mick355 »
Hi all, as this is my first gold pan. I'm after a bit of advise on what I've actually got and what it needs.
mick355
Holes in pan
Post by mick355 »
Hi all.
So i've purchased my first rc10.
The tub has been drilles extensively.
Was this a fad in the day to remove weight?
I don't imagine a factory driver doing something like this.
Would it suggest a decent racing history in your opions?
I've heard there was a drilling template for this but haven't seen one. Anyone got a copy?
Thanks
Mick.
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Re: Holes in pan
Post by Lonestar »
mick355 wrote:Hi all.
Thanks
Mick.
no one in their right mind would EVER do that :mrgreen:
http://www.rc10talk.com/viewtopic.php?f=35&t=186&p=30812&hilit=halsey+drill#p30812 (for instance... there's many many more!)
Paul
mick355
Re: Holes in pan
Post by mick355 »
Ok, thanks Paul.
Now i need to figure out what ive got. :D
a01butal
Has thanked: 34 times
Been thanked: 40 times
Re: Holes in pan
Post by a01butal »
There is a thread out there dedicated to all the drilled chassis that people have come across in their travels through RC life. I can't remember the exact name and location of it right now but I'm sure someone will contribute it shortly. In this cheese grater chassis topic there is a post of template that was found in Competition Plus that was designed by the AE engineering gurus and purportedly used by the AE factory drivers bitd.
This is all very interesting!
Re: Holes in pan
mick355 wrote:I don't imagine a factory driver doing something like this.
someone needs to see a pic of tony neisinger's rc10 from the '85 worlds. :mrgreen:
maybe if/when al isn't busy he could pull a screen shot from the gene husting video and post it up. i don't believe i've ever seen it on here.
mick355
Re: Holes in pan
Post by mick355 »
Thanks guys, looking forward to seeing some video.
If any of the gurus on hear could have a look at my other thread "help to id" i'd really appreciate it.
Hoping it's not to much of a mish mash of parts.
So far i think i'm correct in saying it's a pre stealth A stamp.
Re: Holes in pan
i merged your posts together.
a01butal
Re: Holes in pan
Post by a01butal »
Re: Holes in pan
there it is, thanks al. :)
Percymon
Re: Holes in pan
Post by Percymon »
Nowadays there's no real need to drill the chassis - the enclosed nature means that if you're not racing you can use lighter weight soft lipo packs.If you drill the chassis then you'd be advised to run hard cased lipos to save and damage to the pack from debris etc - any weight gain from drilling the chassis is negated by the heavier hardcase lipo pack.
Of course if you are racing then you'd probably have to use a hard case pack to comply with the rules.
Re: Holes in pan
yeah, drilling holes was very common, but at least yours look like the guy did a nice job drilling them on center and neatly. It should stay pretty strong as is, the rails don't look chopped down. just yeah, you will get debris in the chassis when you run it, but probably not an issue.
mick355
Re: Holes in pan
Post by mick355 »
I'll probably run a stick on cover on the chassis to stop the debris.
I would like to make sure the towers are correct for the chassis. It came with the six hole front as a spare.
Not sure if its a cadillac or earlier??? The battery strap appears to be fibreglass and not nylon.
Yeah the holes are done quite well. I would like to strip the anodising back, and have it retreated.
With the peroxide do i just mix up a small batch and use a toothbrush to clean all the white parts.
mick355
Re: Holes in pan
Post by mick355 »
MODS.
Can this thread please be moved to the Tech section. And the name changed to "ID help please"
Struggling to get the ID answers I'm after and I think it will be better suited in that section.
Re: Holes in pan
you mean whether it is an edinger or cadillac car? It's probably cadillac. looks like the car was run and run well. without any box or documentation or early parts, it's hard to tell and your guess is as good as anyone's.
look at this thread for a guide to the timeline, you will see you probably have more 'cadillac' car than anything else.
http://www.rc10talk.com/viewtopic.php?f=35&t=13059
as for peroxide, that's your call. the parts weren't minty white when new, so if they aren't super yellow, then they will look good cleaned and scrubbed up.
