Scan Request - RC10T2 Decal Sheet
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
I did a search and nothing came up.
I'm looking for a high quality scan of an RC10T2 decal sheet, prefer an exact size scan.
Thanks,
RJ
Thanks,
RJ
- RC10th
Re: Scan Request - RC10T2 Decal Sheet
Anyone?
Even a partial sheet ?
- Been thanked: 81 times
- Has thanked: 1129 times
- Been thanked: 3919 times
- Has thanked: 100 times
- Been thanked: 205 times
Nice
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
Not sure why but my lexmark cant "see" yellow apparently
I have a pdf if it helps with sizing, but no easy way to host it. It also lacks yellow. stupid printer.
X2 . I had the same problem with a HP. Every setting I tried same thing.
- Vale
- Been thanked: 4 times
Have you found a good solution?
I would also be interested...
Cheers,
Daniel
Cheers,
Daniel
- RC10th
I forgot about this after weeks of no response, thanks for all the effort. You can email me a file if you like, just PM me.
I wonder why the yellow gets faded out?
Do you mind posting the PDF? The photobucket image isn't showing for me. Could you also post the dimensions of the sheet. Thanks!gomachv wrote:Not sure why but my lexmark cant "see" yellow apparently
It wasn't a good scan- yellow was missing. Hopefully someone can post a proper scan for you
I don't mind about the color because I'm going to recreate the sheet as a vector graphic and add the missing colors. I'll post the file here afterwords. I started with the one previously posted, but dekeystoning will take a lot longer.
- RC10th
Any scan is better then none.
The "Yellow" can be recolored.
Does anyone make a reproduction of the decal sheet? I've been searching eBay for some time and just find small pieces of it.
Javier -
- RC10th
I can make a reproduction, or at the very least a good print of one with a scan. A friend of mine is a graphic designer and can make decals.
This car was made just by printing scans of decals I already had from a sign shop, they aren't great but could have been made better. The sign shop couldn't print white and didn't seem terribly interested. They are fine for a runner.
This was all before I found out my friend could make decals and could print white.
- 2664 Views
Last post by sandkil
- 3614 Views
Last post by RC10WORLD
- 6798 Views
Last post by SoloGraphix
- 1363 Views
Last post by ZED32
- 1414 Views
Last post by mAdMan
- 930 Views
- 865 Views
Last post by littleVETTE
- 2638 Views
Last post by R Cane
