GT2 interceptor decal sheet #7999
Forum rules
mAdMan
Has thanked: 134 times
Been thanked: 87 times
Post by mAdMan »
Original size is 9x13”
mAdMan
Re: GT2 interceptor decal sheet #7999
Post by mAdMan »
I attempted to have these printed but no one can print white on clear vinyl “decals.” Literally no one I tried 5 print and sign shops.
After, I noticed that my GT2 RTR bodies are printed on white vinyl with a gradient color scheme using gray and black ink.
Has anyone else noticed this? What sticker kit do I have? Did GT2’s come as factory team kits that I’m unaware of?
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
I've got a NIB GT2 body, I can have a look at the decal sheet if you want?
romulus22
Has thanked: 900 times
Been thanked: 789 times
Post by romulus22 »
mAdMan wrote: Thu May 09, 2024 12:37 am
I’m not sure I understand your question correctly? They did sell a factory team truck and a RTR model. Or is it just your sticker set doesn’t match any you have or seen? It looks like it’s basically the same as the one I have.
Dangeruss
Has thanked: 425 times
Been thanked: 1410 times
Post by Dangeruss »
GT2's came as an RTR (kit # 7092) and a Factory Team (kit # 7080). Your #7999 decal sheet would have come in the box with the FT kit whereas (obviously) the RTR decals were pre-applied.
Sign Shops and Print Shops as you found aren't equipped to print on clear vinyl. You can search online for "clear decal printing", as some of the shops are only about an hour from you. But the problem you're going to run into is if (when) they ask for a copyright release. Could also try talking to Nathanial at MCI, being in Canada he doesn't have that problem.
mAdMan
Post by mAdMan »
I guess I didn’t realize that there were clear decals in Ft kits and RTRs had a different kit
mAdMan
Post by mAdMan »
I’m gonna let go 1 or 2 of my GT2’s and one of them is a bit “special.”
One has a display clear plexi top and a black body with black chassis, blue exhaust. The other the body was cut on the windshield badly and I wanted to include a new sticker - seeing as the piece that was cut out is still in the box. It could easily be covered up or repaired for a shelf/display car.
romulus22
Post by romulus22 »
I would just cut out the side window and clean up that front hole with a dremel and call it good. It’s better for nitros to have more breathing anyway so I wouldn’t even worry about closing up the hole.
mAdMan
Post by mAdMan »
romulus22 wrote: Thu May 09, 2024 4:58 pm I would just cut out the side window and clean up that front hole with a dremel and call it good. It’s better for nitros to have more breathing anyway so I wouldn’t even worry about closing up the hole.
Do you think it’s more likely this would be a shelf car for someone or do you think they would use it?
romulus22
Post by romulus22 »
I don’t think there are many “collectors” of GT2s. Let alone rtr version models. I would think there’s a much larger market that plans on using the truck than shelf it. I’m almost embarrassed having that body sitting on a used chassis on my display shelf. :lol:
mAdMan
Post by mAdMan »
Dangeruss sent me the JPEG for the RTR window stickers. Thank you! I even had them die cut!
