Alternative to original XX velcro battery strap
LosiXXkid
Post by LosiXXkid »
In case anyone is interested, I found these to be a perfect match to the original XX velcro battery strap set - A4010:
http://www.ebay.co.uk/itm/16mm-Black-Velcro-One-Wrap-Cable-Ties-Hook-Loop-5-Straps-Strips-200mm-/270864422983?pt=UK_Computing_Cable_Ties_Organisers&hash=item3f10c71847
This is a UK based seller so shipping to the USA would obviously be more.
Synergy
Has thanked: 127 times
Been thanked: 72 times
Re: Alternative to original XX velcro battery strap
Post by Synergy »
Thank you :D
Here's my TC Showroom
DerbyDan
Been thanked: 19 times
Post by DerbyDan »
I wonder if there's anyone out there doing similar Velcro straps but in neon yellow? I replaced the original black straps for the yellow ones that were sold by UK Losi distributers 'Helger' under the Trick Bits banner Bitd, I would love to find some more for my recreation of that old XX 8)
slapshot1979
Post by slapshot1979 »
Im now embarressed :oops: to say what I paid for my NIP ones for my boxart build. good find thanks
LosiXXkid
Post by LosiXXkid »
DerbyDan wrote:I wonder if there's anyone out there doing similar Velcro straps but in neon yellow? I replaced the original black straps for the yellow ones that were sold by UK Losi distributers 'Helger' under the Trick Bits banner Bitd, I would love to find some more for my recreation of that old XX 8)
There's this option but not sure whether it's the right shade of yellow:
http://www.ebay.co.uk/itm/5m-of-Yellow-Velcro-One-Wrap-cable-tidying-strip-16mm-/360599726610?pt=UK_Computing_Cable_Ties_Organisers&hash=item53f56b2a12
However, the downside is that you'd have to buy 5m.....
Then there's this option:
http://www.ebay.co.uk/itm/Hook-Loop-Velcro-One-Wrap-Self-Grip-Strapping-Cable-Ties-Etc-25mm-Per-1m-/170816596237?pt=UK_Crafts_Sewing_Supplies_MJ&var=&hash=item27c576690d
....but unfortunately it's 25mm wide so you would need to trim it down 16mm to achieve the correct width.
K
LosiXXkid
Post by LosiXXkid »
Just thought of another option......
This is only 4mm wider than the original XX velcro battery straps so it will fit the front loops but not the rear, it would definitely need to be trimmed. And, being white, you'd be able to dye it using some Rit fabric dye the colour of your choice.
Colour co-ordinated battery straps......now there's a thought.....!
CGMike
Post by CGMike »
Does regular velcro from walmart not work? Just asking. Great find!
LosiXXkid
Post by LosiXXkid »
The item is a genuine Velcro product and is branded as One-Wrap. It's essentially hook on one side and loop on the other and it simply sticks to itself.
Normal Velcro usually comes in two parts, hook and loop, that you either stick or stitch to whatever you want to join together.
Hope that helps. :)
Return to “Losi Forum”
