ProCat SE? getting ready for a semi rebuild
farmer
Post by farmer »
hey guys this is a a car i picked up a few months ago and im getting ready to do a semi rebuild
just basically a good clean up and tighten
from what ive gathered its a procat se due to the dark chassis
please correct me if im wrong
i know this is a kyosho body but that is what it came with
ill get a repro
couple of questions
1. what and why is the crash back system that i have read about
2. im needing some front drive shafts do all the models of the 4wds run the same
can there be others used?
3. wing stays and the correct #for the wing that should be with this car
thx guys for your time this is my first schuey,,, but im really looking at the new 2wd schuey for my modern buggy running
any help would be great
thx farmer
Has thanked: 1075 times
Been thanked: 3680 times
Re: ProCat SE? getting ready for a semi rebuild
If you cut the zip tie at the front end of the car and install a couple large orings in the same fashion as the zip tie you will see the crash back system. It just allows the front end to fold back if there is an impact.
I'm not too familiar with the 4wd cats so that's about all I can help u with.
Factory Works website
CAT3K
Post by CAT3K »
That looks like it's a CAT XLS rather than a Procat. It has some nice bits on it too :) the layshaft looks like MMS/Trinity. I'm can't remember who made the chassis, but it's not a Schumacher item.
Paul.
Bormac
Has thanked: 21 times
Been thanked: 11 times
Post by Bormac »
Farmer it looks like an XLS Cat. The chassis is definately an after market Procat item (unless the white fibreglass sheet has been dyed or painted black.
To build this car into a Procat SE you'll need a lot of other items if you are to do a descent job of it. However, if you would consider an XLS to be on your want list (and lets face it who wouldn't :mrgreen: ) all you'll need is the correct lower chassis plate and a repro CAT bodyset.
In my opinion the XLS is more sought after now days than the Procat. At the very least they fetch higher prices (for your interest).
-Jason.
Still known as- bormac
V12
Been thanked: 100 times
Post by V12 »
gomachv wrote:If you cut the zip tie at the front end of the car and install a couple large orings in the same fashion as the zip tie you will see the crash back system. It just allows the front end to fold back if there is an impact.
It´s exactly like this. :) O-rings are intended from factory and did work, I just used the zip ties when I had no o-rings left.
The chassis really look like aftermarket, but also like graphite not black fibreglass. Did Composite Craft make such chassis?
I also can see an orange frontbelt so should be a Wasp belt.
CAT XLS is what I did run also back in the days, maybe my most succesful 4WD car after the Kyosho Optima. Just good I got a XLS again last year.
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
The lower chassis is similar to Procat Schumacher no. U288W but not a complete match.
CAT SWB, XL, XLS, Procat and Bosscat, TopCat, Club10, Nitro10, Cougar mkI /mkII uses the same type of drive shafts.
If You wan´t oneway shafts, You can leave out the 2wd buggy´s
Gone fishing
farmer
Post by farmer »
thx guys for the replys
i want to keep it a XLS
im not worried about how valuable the model is
i just want get it going
couple more for ya
is there a part # for the crash back o-rings where are you guys getting yours
or can i just run some rubberbands
also oneways should be the common on the front drive shafts ?
or did the run both
also is there a part#
are does anyone have some they want to part with
also a part # for the wing stays
ill get some pics up later of the chassis maybe you folks can ID it better
thx farmer
Bormac
Post by Bormac »
I don't use one ways on the cars I drive. I find that in low grip situations running solid shafts up front give me a more consistent drive.
As for the crash back rings, a solid rubber band (I use a thick red one) works better than the kit supplied junk.
-Jason.
Bormac
Post by Bormac »
Going the XLS route will be the easiest and most cost effective route as you have almost all you need. Add to that you have some nice chrome rims there you can bet this beast will look ace out on the track.
-Jason.
Jay Dub
Post by Jay Dub »
Composite Craft chassis btw. -Jeff
DennisM
Post by DennisM »
As for the tension crashback o-rings - I have a bag with parts number U725Y
Gone fishing
Return to “Schumacher Forum”
