Peroxide Question
Peroxide Question
Hey guys I have been a member here for a while and dont post a whole lot but enjoy restoring and collecting RC10s just the same. My qustion is how long should you wait to reassemble the whitened plastics on the chassis. The reason I ask is because on previous projects the anodize on the chassis under and around the plastic became lighter and faded looking.
Re: Peroxide Question
glad you mentioned this, it is a problem I have had. Peroxided a bunch of RC10T parts, cleaned and dried them. Put them in a plastic container with the rest of the parts including the black anodised shock caps, checked them a month later only to see they were no raw silver! I will try to get a picture up.
I didn't know it would effect parts that were in open space?
it's probably a good idea to throw them in some water after they dry, I know it sounds weird, but you let the parts leach out water and peroxide by drying, then put them in water to allow fresh water to dilute what is in the nylon. I would say you could probably boil them up too, but it's probably good enough to let dry, then soak again overnight. Oh, I'd use a lot of water say like at last a gallon even just for a handful of parts.
it's the first I've heard of it, but I doesn't surprise me that peroxide leaches out slowly once you soak in it.
- Has thanked: 36 times
- Been thanked: 1318 times
a little while back i whitened a 10t bulkhead for use on a worlds setup. 2 days later i bolted it to the chassis and attached the new white rpm worlds arms and old style white bumper. the next day, the rpm parts were greenish yellow. typical of what happens to those parts in peroxide. i tore the front end back apart and boiled all of the parts. the arms and bumper became white again, and i put it back together. next day, i had greenish yellow rpm parts again.
3 times i had to boil and cool those parts until the peroxide would stop weeping out of that damn bulkhead.
- Has thanked: 1129 times
- Been thanked: 3919 times
Dang, I haven't had that issue yet but I should probably start boiling my parts just to be safe.
Great info guys. I will give the boiling trick a shot. I have a worlds car coming and I want to make sure that I dont mess the ano up on that chassis.
- mdutcher
Yes, great to know.scr8p wrote:a little while back i whitened a 10t bulkhead for use on a worlds setup. 2 days later i bolted it to the chassis and attached the new white rpm worlds arms and old style white bumper. the next day, the rpm parts were greenish yellow. typical of what happens to those parts in peroxide. i tore the front end back apart and boiled all of the parts. the arms and bumper became white again, and i put it back together. next day, i had greenish yellow rpm parts again.![]()
How long do you let the parts boil typically? And it should not affect the integrity of the part, correct?
FT RC10B4.2*Dualsky ESC*Reedy 17.5T*XP
RC10 Re-Re*Dualsky ESC*Reedy 17.5T*Savox
RC10 CE*Novak GTB2*Dualsky 13.5T*XP
RC10T and other vintage goodness
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
Told ya-scr8p wrote:a little while back i whitened a 10t bulkhead for use on a worlds setup. 2 days later i bolted it to the chassis and attached the new white rpm worlds arms and old style white bumper. the next day, the rpm parts were greenish yellow. typical of what happens to those parts in peroxide. i tore the front end back apart and boiled all of the parts. the arms and bumper became white again, and i put it back together. next day, i had greenish yellow rpm parts again.![]()
Shock the parts in ice water after boiling too- helps express any chemicals in the plastics out
When dying I boil for around 5-10 minutes. Boiling was recommended to me when I first started in rc because it made the nylon more flexible. Not sure if its true but I've never had any issue with a dyed part that wouldn't have been a failure on a stock part.
- Been thanked: 4 times
I LET MINE SIT ONE MONTH BEFORE ASSEMBLY AFTER PEROXIDE TREATMENT NO DAME TO CHASSIS YET.DON
- mdutcher
Just out of curiosity, what is the process for using peroxide? Just soak? If so, how long?
I have a set of parts in peroxide right now actually. I just lay down foil into a Rubbermaid container, pour in a bottle of peroxide (enough to cover parts) and drop in the parts. Let sit in the sunlight stirring once in a while unt you reach the whiteness you desire. With Oregon sunshine it takes a few days or more to see a change. I haven't bought a UVB light yet. I bring in my parts at night and cover the container keeping it dark until morning when I put them back out
I have been setting mine out daily. Got a few rays today. A reptile bulb (UVB ultraviolet "b") has been recommended but I'm too cheap to buy one
- 874 Views
Last post by Quasi
- 2391 Views
Last post by klavy69
- 1099 Views
Last post by GeneralZod
- 947 Views
Last post by Lowgear
- 46 Replies
- 4585 Views
Last post by JosephS
- 30 Replies
- 4819 Views
Last post by Zedmaster
- 1716 Views
Last post by Winger
- 3730 Views
Last post by Jedi Master
Users browsing this forum: DotNetDotCom.org [Bot] and 2 guests
