hydrogen peroxide, am I missing something?
spennyy2k
Post by spennyy2k »
So after reading the threads I found on Google my trx1 was left to soak in some 6% hydrogen peroxide in a jar. It's been in there for almost a week and there doesn't seem to be much or any improvement. It's sat on the window sil inside and when I'm home I put it in the back garden for some direct light tho it is mostly cloudy atm. Do I need a stronger mix or re clean the parts and give them another soak in fresh hp?
RC104ever
Re: hydrogen peroxide, am I missing something?
Post by RC104ever »
I would like to know too but was afraid to ask :oops:
- Chris
Lots of cars...so many cars
Sixtysixdeuce
Post by Sixtysixdeuce »
It needs heat first and foremost, and the UV from sunlight also helps.
When I want to whiten parts quickly, I'll throw them in 30% and warm it to ~170F for 1-2 hours.
spennyy2k
Post by spennyy2k »
Ok. I'll try that as well
marlo
Has thanked: 18 times
Been thanked: 22 times
Post by marlo »
You need the sun, and I find, heat as well.
http://www.rc10talk.com/viewtopic.php?f=40&t=14978&hilit=+hydro
DMAT
Post by DMAT »
I did this last weekend, there was way too much overcast. I left it outside for 2 days straight or so and I could see a noticable difference. I didnt have additional head but I'd say direct sunlight definitely plays a part in it working. I remember a thread somewhere that advised against anything over 3% or it would eat at the part. I have no clue if thats actually true but I dont know where to get anything over 3%.
I know most parts are made of nylon but I noticed certain parts would not lighten at all after a few days. Maybe there is a slight varient in the materials.
Summer is coming so 90-100 deg days are only a month or two off so I'll see if some heat helps the process.
I tried the UV lightbulb thing but got absolutely nowhere. I had it under constant light for a week or so straight and nothing happened.
Sixtysixdeuce
No, stronger solutions don't hurt the parts. 20-50% stuff can be found at beauty supply shops. I have not seen anything stronger than 50% anywhere.
marlo
Post by marlo »
DMAT wrote: I tried the UV lightbulb thing but got absolutely nowhere. I had it under constant light for a week or so straight and nothing happened.
I tried that as well,.......... nothing.
Been thanked: 3917 times
UV or UVB? From my research on this site you need to make sure it has the "B" as thanks the critical ray needed to activate the peroxide. Again, going from what I have read but it would be helpful to know if those that are having trouble are using the UVB or just a UV
myfordcnc
Post by myfordcnc »
I'm wondering if the window has any thing to do with it. Some modern windows are designed to block a lot of uv.
^ oh that's a good point too!
spennyy2k
Post by spennyy2k »
That's why I've been putting it outside when I'm home during the day
myfordcnc
Post by myfordcnc »
just realized the problem. You're in the UK. No sunshine there. :D
IDK maybe this would help. I put my parts in a larghish clear bin and set up mirrors to direct light right on the parts. While being outside.
Though I have yet to get results like some of the other people here. Better but not as good as what I have seen here.
spennyy2k
Post by spennyy2k »
Yeah there has been a lack of sunshine here for the last 1000 years or so. I tried to source a lamp to use locally but no luck yet
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
I thought stronger solutions can make the parts chalky, heat definately makes a difference as it opens the pores of the nylon. Also using a BBQ tray or making a tin foil dish helps collect the rays.
I find leaving them outside on a full or near full moon makes a difference too.
Remember too peroxide is sensitive to light and can go off (reason it's stored in dark bottles). Might try getting some fresh stuff and trying again.
Also many people over whiten parts which looks wrong. Should be more ivory then white.
