Scorpion vs. Scorpoion Turbo - What's the difference !?!?
loftfind
Post by loftfind »
Yeeello
OK - so apart from the obvious (different paint job / wheels / wing brace) can any scorpion experts out there tell me what the difference is between the 2 cars? cheers muchly - lofty :mrgreen:
Been thanked: 3919 times
Re: Scorpion vs. Scorpoion Turbo - What's the difference !?!
Body, rims and tires, motor, shocks, bumper, speed control heat sink, gear diff on turbo, and I would swear I read the rod ends were stronger
loftfind
Post by loftfind »
thanks
1300GT
Has thanked: 486 times
Been thanked: 406 times
Post by 1300GT »
Yep, the ball ends are 5.8mm on the Turbo and 4.8mm on the Scorpion. The Turbo's rear suspension plate is one piece and the Scorpion's is two pieces. Chris.
Chris.
Toys.............they are!
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Post by Hcp22 »
The gearboxes are different: the TS-box has three attach points for the shock tower and a casted ring around the outdrive to prevent dirt getting in behind the gear cower and early versions didn’t have dustcover behind the motor plate. Gear ratio is different. The TS has 10mm shocks instead of 8mm. The lock mechanism for the battery lid is different. The body, roller bar and cage, roof, radio box, wing and wing stay, drive hubs aluminum/steel, motor cover. There are probably more that I have foreseen. :D
Cheers
Lars
My Feedback
Hotrodvw
Post by Hotrodvw »
If I remember right, the Turbo had a true differential, where the Scorpion had a spool (locked up solid, no diff).
Return to “Kyosho Forum”
