Scorpion & Turbo Scorpion gear pitch?
mjtown
Post by mjtown »
Hi all,
I'm thinking that with the extra grunt that I'm going to be putting through my Turbo Scorpion drivetrain, I should look at putting the old gears in a bag and finding replacements of the same pitch or maybe even replacing with a different pitch.
Does anyone know what the gear pitch is in the TS? Is it the same as the normal Scorpion/Tomahawk/Beetle/Sidewinder?
Has anyone successfully found replacements other than original parts?
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Re: Scorpion & Turbo Scorpion gear pitch?
Post by Hcp22 »
You can find replacement for all gear s except for the center-gear, at least not to my knowledge. The gear is metric 1.0
Cheers
Lars
My Feedback
mjtown
Post by mjtown »
Thanks mate - yeah, that centre gear's a bitch.
The counter gear can be changed for the CRP brass item. Various 1.0 pinions are available on eBay.
Centre gear? The guy from Time Tunnel 'melted' his original gear so he had some ground from polyoxymethylene/POM/delrin/acetal (whatever you want to call it). I was thinking that bonding two delrin 1.0 module gears together would work (or you could use a 1 module 12T gear and bond a larger 32 pitch, or 48 pitch gear to it)
After a fair amount of internet searches I found these:
http://www.smallparts.com.au/store/item/gs100120900b0600achp/gearsspurmodule1/
http://www.smallparts.com.au/store/item/gs100240900b0600achp/gearsspurmodule1/
http://www.smallparts.com.au/store/item/gs100180900b0600achp/gearsspurmodule1/
There are other pitch gears on that site too.
Apparently delrin's quite hard to bond, but this CA glue claims to bond it well:
http://www.dymax.com/products/cyanoacrylates/pacer_cyanoacrylates/index.php
I think that reinforcing it by micro-drilling through both gears and inserting wire 'pins' should work quite well.
For now I'll use my 20T/12T centre gear (and the 22T/12T one that's on it's way from the UK) but I'll try the above method if it looks like I'm starting to trash them!
Hcp22
Post by Hcp22 »
Sound interesting, place let us have some pictures on your work. :D
Cheers
Lars
My Feedback
mjtown
Post by mjtown »
Will do mate - but I'll get this Optima Pro stripped down first :wink:
scootmike
Has thanked: 8 times
Post by scootmike »
I'll be watching for this, I'm in the same boat, you would think somebody would repop the center gear.
Mike
turbo scorpion
Post by turbo scorpion »
do any of you know where i can find shocks for the TS? repro or substitution ones are fine.
Hcp22
Post by Hcp22 »
turbo scorpion wrote:do any of you know where i can find shocks for the TS? repro or substitution ones are fine.
Yes; I used modern aftermarket damper from Yeah Racing. They have an 11.8mm damper in various lengths, so I chose 60mm for the front and 70mm to the rear. http://www.rc10talk.com/viewtopic.php?f=30&t=21558
Cheers
Lars
My Feedback
turbo scorpion
mjtown wrote:Thanks mate - yeah, that centre gear's a bitch.
did you find a suitable replacement for the center gear???
keithrc
Has thanked: 20 times
Been thanked: 15 times
Post by keithrc »
Hey Mjtown, sorry to hijack your thread but you mentioned an Optima Pro, do you have any other info on it or a thread about it?
Keith :wink:
mjtown
Post by mjtown »
Not at the moment mate. What did you want to know?
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarYandex [Bot] and 1 guest
