Optima Mid spur gear ratio - give me a starting point
- Been thanked: 325 times
My current project is an Optima Mid that's going to be setup as a mid-motor RWD. It has the ball diff gear innards of a Turbo Optima Mid SE, I'll be upgrading the balls to ceramic and will polish the diff plates to smooth (wet-sanding with 1500-grit).
The stock spur gear & slipper on this car has been upgraded to a 48-pitch fine-tooth Robinson Racing gear. I received in this parts lot a series of RR gears, from 75T to 93T I believe, and one pinion gear to match that's a 14T. I believe the previous owner had it setup with the JG Racing truck conversion.
I also received a bunch of stickers showing all the various pinion/spur gear ratios but I'm not sure which spur gear I should start with; a smaller or bigger one? I'm installing a 12T brushless motor & ESC combo from Toro.
http://www.ebay.ca/itm/SKYRC-toro-leopard-12T-2p-Brushless-Motor-3300kv-60A-V2-ESC-RC-car-truck-buggy-/290825206167?pt=US_Character_Radio_Control_Toys&hash=item43b6887997
That all being said, I'm intending to run it as a RWD-only and would like some suggestions for a starting point for a final gear ratio...what combo of pinion & spur should I start with?
Re: Optima Mid spur gear ratio - give me a starting point
Thanks to all the crickets for answering...how about some Optima Mid enthusiasts?
EDIT: Looks like I have a starting point, anyway...the very last post in this topic on Oople suggests an 18T pinion & 81T spur gear. Thanks crickets!
http://www.oople.com/forums/showthread.php?t=4888
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
I would start with an 18T pinion & 81T spur gear...
p.s. it actually is what my optima mid is at but I have no real idea
what is the internal ratio? The 18/81 is a good start if the internal ratio is around 2:1 or so. Really, with a brushed motor you are gearing for run time and motor temps, so you will have to adjust from there.
- Has thanked: 36 times
- Been thanked: 1319 times
according to a twister motor sheet, the optima mid is a 2.64:1.
whoops...the 12t thing confused me, I thought you were running brushed. 12t isn't a 'common' brushless wind.
so you are concerned with motor temps. with that internal ratio, the 81/18 is probably fine, but you may find you will be going up a bit on the pinion. Better to work your way up to motor temps than to smoke it being overgeared.
What scr8p said. He must have some Kyoshos stashed somewhere...jwscab wrote:what is the internal ratio? The 18/81 is a good start if the internal ratio is around 2:1 or so. Really, with a brushed motor you are gearing for run time and motor temps, so you will have to adjust from there.
Thanks gents, I'll see what spur gears I have, I have a good selection to choose from...48p pinion gears, not so much.
- klavy69
- Moderator
Coelacanth wrote:What scr8p said. He must have some Kyoshos stashed somewhere...
- 1130 Views
Last post by JK Racing
- 1104 Views
Last post by aconsola
- 1955 Views
- 2289 Views
Last post by Hcp22
- 1005 Views
Last post by farmer
- 2484 Views
Last post by THEYTOOKMYTHUMB
- 21 Replies
- 5241 Views
- 468 Views
Last post by ongbenghui
