Bottom loader shock question
- Has thanked: 1129 times
- Been thanked: 3919 times
Anyone ever have any luck removing a retaining ring after both ends are broken off
I have the shock gutted so there is plenty of room to maneuver just no way to pry it out. I've broken a couple xacto blades trying to snake under one end and it just isn't happening. Wondering if anyone has a trick up their sleeve.
- Has thanked: 170 times
- Been thanked: 23 times
Re: Bottom loader shock question
Have you tried a dental pick. Not a common item to be sure. Could be of help and much more sturdy that an exacto tip.
I do use a set of automotive pics, but I don't have enough meat to be able to grab a corner.
the closest I got was digging in around the middle of the clip, but the blades are just too fragile. My precision screwdrivers are too soft, already bent he tiny one. They aren't the cheapie ones either! Doh!
- Been thanked: 81 times
Hey . If your working on A-stamp shocks I have a set of shock bodies you can have. Fronts are in great shape .Rears have some ano worn off at the bottom.
I am building a Mcallister conversion so all 4 are short .56 shocks. If you want to part with the .56 bodies I'd gladly put them to good use
Ill shoot you a pm
Ill shoot you a pm
it will kind of take two hands and maybe 2 more. If you can support the shock body in a vise, do that. I normally use the plastic hex wrench on the hex, and lightly clamp in the vise. Now get a dental pick and an xacto blade, and snap off the tip so that it's got a flat about 3/32" wide or so. alternatively, you can use anything really small and stiff with a decent edge on it like a jewelers screwdriver. try and spin the clip in the groove. if you can do that, you should be ok. Hold the pick so that you jam the tip into one of the broken edges, and use the xacto to push the clip around to the pick. that should push the clip up onto the dental pick and out of the groove so that you can kind of unwind it out of the groove. This is NOT easy and takes some concentration. The tools are very sharp and you need to use a lot or pressure. You may also have to tweak the tip of the dental pick to make it sharper or flatter, etc.
Ahhhh basically building a ramp to derail the clip... Great idea ill give that a shot tonight. The clip is loose enough in the groove that I can walk it around.
I also just broke the c-clip , what do you use to replace the original c-clip ? Saw the Associated shock rebuild kit #6440 has a square clip instead , will this kit work with the older shock's , thanks .
- Been thanked: 4 times
Use a piece of cloth rubbing around to catch the broke end and pull inward to pop it.DON
I never did find a part number for the retainer but if you measure it carefully I bet McMaster Carr has thempituk wrote:I also just broke the c-clip , what do you use to replace the original c-clip ? Saw the Associated shock rebuild kit #6440 has a square clip instead , will this kit work with the older shock's , thanks .
I was lucky enough to find a rebuild kit for mine. The new ones will not work
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Home Depot sells the 3/8" internal retaining rings for bottom load shocks. You can find them in the drawers located in the hardware isle.
http://www.homedepot.com/p/Crown-Bolt-3-8-in-Internal-Retaining-Ring-80458/202210113
EDIT: scratch that I think 3/8" were for the 6-gear drive cups. The bottom loader rings are smaller.
The Traxxas shock rebuild kit comes with the circlips, and blue x-rings that fit in and seem to seal well.
- marlo
- Has thanked: 18 times
- Been thanked: 22 times
I did the same conversion last year, had to cut a front tower, other then that should be bolt on kit , fun to dogomachv wrote:I am building a Mcallister conversion so all 4 are short .56 shocks. If you want to part with the .56 bodies I'd gladly put them to good use![]()
Ill shoot you a pm
- marlo
I use a dental pick as well, works great!aip47-2008 wrote:Have you tried a dental pick. Not a common item to be sure. Could be of help and much more sturdy that an exacto tip.
I ordered them from mcmaster-carr... i think they were 1/4 by .015 thick. I'll clarify with the part number. As always if dont have another order going to mcc then best to go to home depot.
ALL OVAL RACING:
SC10 Late Model
SC10 Modified
SC10 Bomber
Cobra Nemesis Sprint
B4 Street Stock
TC3 Late Model
SC10 Late Model
SC10 Modified
SC10 Bomber
B4 Street Stock
TC3 Late Model
- 1435 Views
Last post by GeekSpeed
- 626 Views
Last post by isaidme
- 1050 Views
Last post by bully
- 1018 Views
Last post by Bakauata
- 562 Views
- 509 Views
- 449 Views
Last post by adam lancia
- 23 Replies
- 1377 Views
Last post by juicedcoupe
