How compatible are the parts from the original bottom load shocks with the black cap top loading shocks?
Can I use the earlier gold caps from the bottom loaders on the top loaders?
Will they work work with the black o'rings from the black caps? Or could I use the gold caps with the nylon gasket?
I'd like to build a set of top loaders with gold caps if possible.
Or should I just build the bottom loaders and use those? Are they that much worse than the top loaders?
Thanks in advance
Chris
Bottom load - top load shock cap compatibility
- Has thanked: 41 times
- Been thanked: 91 times
Re: Bottom load - top load shock cap compatibility
All associated small bore caps are interchangeable, nylon cap gaskets are not that good, generally o rings are better. Bottom load shocks are no better or worse than the later top loaders, just harder to work on unless you have the proper circlip pliers.
- Bakauata
- Has thanked: 35 times
- Been thanked: 23 times
Great. Thanks for the super quick response. I'm working on this now and was holding off form committing to one or the other.
I am surprised though that the caps are considered completely interchangeable, since the black o'ring is not captured by the gold cap, and therefore works more like a gasket than with the nylon cap which envelops the o'ring.
Chris
- 1436 Views
Last post by GeekSpeed
- 1139 Views
- 1454 Views
Last post by littleVETTE
- 1094 Views
Last post by MattiasL
- 21 Replies
- 2813 Views
Last post by greene-r74
- 48 Replies
- 5951 Views
Last post by CATS
- 3694 Views
Last post by ChisaiKuso
- 28 Replies
- 3081 Views
Last post by askbob
