Protective covering for chassis underside
- mdutcher
I knew at one time there were some options for this sort of thing back in the day. I found a website that still offers this sort of product, but not for the gold tub or black tub chassis. Has anyone tried to use standard contact paper with any great success? What about other options?
FT RC10B4.2*Dualsky ESC*Reedy 17.5T*XP
RC10 Re-Re*Dualsky ESC*Reedy 17.5T*Savox
RC10 CE*Novak GTB2*Dualsky 13.5T*XP
RC10T and other vintage goodness
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Protective covering for chassis underside
Tram blue groove sells a full undertray in lexan and its pretty cheap. I know you are asking about the adhesive kind, but I never liked the look of the associated stuff plus it was a pita to remove the residue. Just my 0.02
- mdutcher
I googled team blue groove.... are you referring to them on eBay? I only see that it refers to an eBay store? I tried searching on eBay, but am not getting to the right area though.gomachv wrote:Tram blue groove sells a full undertray in lexan and its pretty cheap. I know you are asking about the adhesive kind, but I never liked the look of the associated stuff plus it was a pita to remove the residue. Just my 0.02
This is the eBay listing for the full length undertray for rc10:
http://bit.ly/PeZCWp
Of the link doesn't work, here is the item number
150676712276
150676712276
- mdutcher
Sweet! Thank you. I just was not getting there.gomachv wrote:This is the eBay listing for the full length undertray for rc10:
150676712276
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Another option is LowClassCC if he still sells it.
http://www.rc10talk.com/viewtopic.php?f=68&t=12309
- Been thanked: 81 times
The lexan under trays just split apart after a few runs. Go with film .
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
And when sand gets between the tub and bellypan it will start scratching the anodising.
Item # AZ-0010
http://www.team-azarashi.com/prodenglish.html
You can try contating Bill from Clinehobbies (member here) : I remember he was their reseller in the US
The best way I found is to remove everything from the surface, apply the film puncture the screw holes and re-install everything. It's cumbersome, but other wise you have to cut holes when you want to loosen a screw , and the cut holes gather dirt and tear.
Item # AZ-0010
- 43 Replies
- 8080 Views
Last post by Y'ernat Al
- 1087 Views
Last post by MOmo
- 1133 Views
Last post by orangemazda
- 718 Views
Last post by mikea96
- 610 Views
Last post by adam lancia
- 615 Views
Last post by RC10resto
- 30 Replies
- 4811 Views
Last post by Peakey
- 1075 Views
Last post by templeofspeed
