B3 Diff build question
Im putting together a factory team b3 kit that i got in a trade. I was putting the diff together and had a question before i proceed. Does #6575 the long screw go through that plastic washer with the ears or does that sit on the outside of the screw? Just dont want to have to pull it apart so i stopped until i get the correct anwser. Thanks in adavnce and love this forum.....everybody is so helpful!!
- Has thanked: 36 times
- Been thanked: 1318 times
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: B3 Diff build question
It is shown correctly, it goes into the out drive after the screw as kind of a plug
Ok thats what i did but what stops it from falling out? Thats what made me think that screw would go through it to hold it into place.scr8p wrote:slide it down in the outdrive once the diff is built.
- flipwils11
- Been thanked: 19 times
That washer on the far left is on the outside. It presses in behind the screw with the ears riding in the outdrive cutouts.
it sit in there fairly snug.vwlvr1980 wrote:Ok thats what i did but what stops it from falling out? Thats what made me think that screw would go through it to hold it into place.scr8p wrote:slide it down in the outdrive once the diff is built.
Ok cool thats what i did so now i can proceed......Thanks a ton guys!!flipwils11 wrote:That washer on the far left is on the outside. It presses in behind the screw with the ears riding in the outdrive cutouts.
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
The CVD in the drive cup keeps it from falling out-vwlvr1980 wrote:Ok thats what i did but what stops it from falling out? Thats what made me think that screw would go through it to hold it into place.scr8p wrote:slide it down in the outdrive once the diff is built.
- 749 Views
Last post by e123
- 934 Views
Last post by NickTheGreek
- 552 Views
Last post by NRG
- 923 Views
Last post by a01butal
- 465 Views
Last post by Lonestar
- 1083 Views
Last post by littleVETTE
- 19 Replies
- 2444 Views
Last post by Konich
- 3164 Views
Last post by CON2
Users browsing this forum: Ahrefs [Bot] and 8 guests
