Question: Kyosho Nitro Circuit 1000 to Electric work?
- sgirouard
So I've always loved these buggies but getting an electric one always shoots past my budget. I've seen some nitros go cheaper and wondered what would be involved in converting a Nitro to electric?
- highwayracer
- Been thanked: 6 times
Re: Question: Kyosho Nitro Circuit 1000 to Electric work?
Do you plan on using the same gearbox and motor location (front to back vs. sideways)?
I have a couple of the Rowdy Baja / Bluebird / Challenger 1/8 buggys and I was thinking of a brushless conversion for one of them. I was going to use the same set up including the clutchbell piece that comes out of the gearbox. Essentially, the brushless motor will sit in the exact same location as the nitro. Just need to figure out if the brushless motor can handle this since there is very little gear reduction.
If you're going to replace the gearbox, then it might get costly looking for the electric components.
- Been thanked: 496 times
If you can make a plate that bolts to the chassis/trans in the same fashion the engine did, you should be able to install a brushless motor. Those circuit buggies are 1/10 or 1/8? I know the 1/8 scale brushless systems are a little pricey. You'll take out the 4 cell receiver pack and gas tank, and hopefully, that makes enough room for a battery pack. One thing you can look into is the shorty pack for the losi 22(if they are 1/10 scale)
- highwayracer
I beleive the 1000 series is the 1/10 scale (advance & assault) but the 1/8 scale versions had the same setup...just bigger.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
I think the wildcat falls into this category?
http://www.kyoshoforum.com/showthread.php?t=1429&highlight=wildcat
- Phin
- Has thanked: 82 times
- Been thanked: 230 times
You should be able to convert an Advance or Assault to electric with just the motor plate, cover, counter gear, and center gear from a Scorpion, Beetle, etc.
The gearbox cases are a little different but you should be able to mount the motor plate to the right side of the Advance/Assault case. You'll also need to remove the rear frame rails and the old counter gear box from the opposite side of the case.
- DennisM
- Has thanked: 30 times
Check out Lars´(HCP 22) awesome build.
http://www.rc10talk.com/viewtopic.php?f=30&t=19063
Gone fishing
- 942 Views
Last post by Jirka
- 165 Replies
- 15298 Views
Last post by ron
- 2694 Views
Last post by AYKBOBCAT
- 745 Views
Last post by Qtschmidt
- 3520 Views
Last post by DennisM
- 1025 Views
Last post by photogRC
- 2339 Views
Last post by Frankentruck
- 1163 Views
Last post by mine721
