Lohas rims and what's needed
Hi, what a surprise to find out tonight my girlfriend found and brought me some "dazzle" Lohas rims today while I was at work, I had been looking for a few weeks, was out bid on some sees on eBay recently and she knew how much I wanted some nice rims. Do I need any extra parts like bearings, washers or anything else to fit these rims to a standard rc10. Also can you reccommend tyres that will fit, I am not even sure on tyre size so I would really appreciate any advice.
Mick
Mick
- RC104ever
Re: Lohas rims and what's needed
Congrats - they fit standard 2.2" tires. I believe on the front, you use standard bearings. In the back, I recommend trying the stock bushings to make it fit the axle and once the nut is tight you won't have any issues I think. I haven't tried mine yet, they are just so nice I'm afraid to even run them.
- Chris
Lots of cars...so many cars
Hi Chris, thanks for the reply. I'm in the same boat as you, not sure if I should put them on and use or buy another shelf queen to put them on so I can just to look at them. Is it possible for any one to post pics of the underside of two rc10's, one with stealth tranny and one with ordinary 6 gear tranny. I am having trouble up loading pics at the moment of my chassis, it has an A stamp and six gear tranny ,but there are no other screw holes in the rear besides the ones allready used to install original tranny, so in order to install a stealth tranny will I have to drill extra holes as I have seen some sort of template for this. I would rather keep this chassis original and not drill holes, what model gold pan chassis am I after that has the stealth tranny? Can any of you good blokes steer me in the right direction, thank you
Mick
Mick
Congrats on the rims. I believe you need a B or C stamp chassis, experts please correct me if I am wrong.
Here is a pic of the underside of my car with stealth tranny, notice the 4 extra black screws in the rear of the car.
Regards,
Ren
. by 2500M_Sub, on Flickr
Regards,
Ren
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Associated made a template to drill holes for stealth. I was lucky enough to grab two sets of his wheels. From how Lohas talked, I doubt he will do another run
- RC104ever
Check out rccarbonworks.com - there is a stealth drill guide:
http://rccarbonworks.com/store/index.php?route=product/product&path=20_36&product_id=103
They also carry shock towers and stuff for the RC10 still.
- Chris
- flipwils11
- Been thanked: 19 times
Yes I don't think he will do another set, so with that and their tricky fitment I would not run them. I had to get someone on the board to help get mine to fit nicely by machining some adaptors and they still have a loose fit with some play.
Thanks for all the replies, I really appreciate it. So after looking at the underside of Ren's chassis, I definitely don't have a stealth tranny or the holes for it, thanks Ren for the pic, at least I know what to look for now...what year chassis do I need to get stealth tranny? Also what do I need to buy or ask for in order to fit the Lohas rims to my rc10, people keep saying they are hard to get them to fit right or tight? I want to at least try and fit them Christmas day and have any hardware I may need. Cheers for any advice fellas, it's appreciated.
Mick
Mick
- 1395 Views
- 851 Views
Last post by Synergy
- 209 Replies
- 65207 Views
Last post by rctenracer
- 792 Views
Last post by klavy69
- 1072 Views
Last post by DerbyDan
- 680 Views
- 34 Replies
- 4294 Views
Last post by EvilAsh
- 1767 Views
Last post by UltraHIVE
