Pro Cat, Bosscat, or Cat?
- Has thanked: 4 times
I just won the following car the other day and was wondering if I could get a touch of help identifying the car http://www.ebay.com/itm/Schumacher-CAT-4WD-Off-Road-1-10-Electric-RC-Buggy-for-Parts-or-Rebuild-L-K-/150909810133?_trksid=p2047675.l2557&ssPageName=STRK:MEWNX:IT&nma=true&si=cUPOWtnHJYnZ7dG66EiqacON58w%3D&orig_cvip=true&rt=nc
After looking at the pictures a bit more closely I think it is a ProCat.
Anyone?
Anyone?
- Groomi
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
Re: Pro Cat, Bosscat, or Cat?
Doing a bit of the COVID cleaning around the house and I came across this piece which has pretty much been untouched since I last posted this. I’ve knocked out a few much smaller projects and have worked up the confidence to give this one a go. I’ve been reading up a bit and it seems the parts are mostly interchangeable with the xls. I typically don’t ask questions prior to buying supplies but I figured it would be prudent. Any ideas if any of the following will work
T-260 wing mount brackets
A-093 turnbuckle m3x35
T-098 steering lever
T-099 radius arm
T-170 center track rod
T-144 front end anti roll bar
T-229 95t gear
T-101 servo mount
T-076 mount bracket
A-424 link wire
T-252 wire clamp w/ screw
Front & rear shocks
Thank you in advance for any guidance.
T-099 radius arm
T-229 95t gear
T-101 servo mount
T-076 mount bracket
A-424 link wire
Front & rear shocks
T-099 radius arm
T-229 95t gear
T-101 servo mount
T-076 mount bracket
A-424 link wire
Front & rear shocks
T-099 radius arm
T-229 95t gear
T-101 servo mount
T-076 mount bracket
A-424 link wire
Front & rear shocks
- 4104 Views
Last post by Mad Racer
- 3542 Views
Last post by isobarik
- 4084 Views
Last post by Eau Rouge
- 1755 Views
Last post by Typpo
- 1075 Views
Last post by uzzi
- 6349 Views
Last post by XLR8
- 2304 Views
Last post by RichieRich
- 2309 Views
Last post by kaszal
