Kyosho Land Jump/Silver Fox/Vanning Help
- limestang
- Has thanked: 100 times
- Been thanked: 249 times
I am trying to repair a Thunder Tiger Silver Fox, which I believe is the same as a Kyosho Land Jump and Vanning. I am stuck on how to connect the throttle/brake linkages. The manual I have shows a rotor style carburetor, and mine has a slide type (just like photo shown below). If anyone can post some close up photos showing the servo's and linkages to the carburetor and brakes, I would greatly appreciate it.
- Attachments
- Silver Fox Carb.jpg (26.82 KiB) Viewed 2849 times
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Re: Kyosho Land Jump/Silver Fox/Vanning Help
The Buggy on the picture is a Kyosho Vanning, which doesn´t have much in common with the Thundertiger silver fox.
Which manual are You using?
Gone fishing
- limestang
I have the manual for the Silver Fox Gold Edition. The buggy I own is the Silver fox Green Edition. It looks just like the photo, and shares the slide style carburetor.
- highwayracer
- Been thanked: 6 times
Here's a picture of mine. I have the other type of carb that rotates. you'll probably have to fabricate a different linkage system to get it to work for you.
Regards,
Roger
Regards,
Roger
- highwayracer
I took another look and I think you can bypass the piece that's attached to the chassis. Green goes to the brake and the red goes to carb....both coming from the servo horn.
- limestang
Excellent - Thanks highwayracer!!! I will give it a try. I imagine the rubber gasket that seals the box won't work since 2 linkages will need to be routed.
Thanks Again,
Limestang
Thanks Again,
Limestang
- highwayracer
Thinking about it more...here's another option...that might look better. It uses the L shaped horn on the chassis and allows a single rod to exit from the radio bax.
- limestang
Even better! When I purchased this buggy, all of the linkages were missing, and the throttle/brake servo saver that attaches to the frame was broken. I had considered trying to switch the carb to the rotor style, but haven't had luck locating one. Hopefully I can get this one to work.
- DennisM
This picture is of a Kyosho Vanning, not at Thunder tiger Silver Foxlimestang wrote:I am trying to repair a Thunder Tiger Silver Fox, which I believe is the same as a Kyosho Land Jump and Vanning. I am stuck on how to connect the throttle/brake linkages. The manual I have shows a rotor style carburetor, and mine has a slide type (just like photo shown below). If anyone can post some close up photos showing the servo's and linkages to the carburetor and brakes, I would greatly appreciate it.
Gone fishing
- limestang
Here is a photo of my Green Machine. It was advertised as a Thunder Tiger Silver Fox Green Edition, but I am by no means an expert, so let me know if it's something else. Once I get the servo's repaired, I'm considering the following Green Accents: Powder Coat Frame, Wheels, Anodized Aluminum Servo Horns, Anodize Aluminum Air Cleaner. This has been a fun project so far, I'm very impressed with the chain drive, Aluminum roll cage and suspension.
Thanks Limestang
Thanks Limestang
- limestang
Found this photo on classic.rc.junkies.net, and it shows a clear image of the throttle/brake linkages. Very close to earlier suggestions. Thanks again for all inputs and help on this.
Limestang
Limestang
- DennisM
Thanks, now Rainman can go to sleeplimestang wrote:Here is a photo of my Green Machine. It was advertised as a Thunder Tiger Silver Fox Green Edition, but I am by no means an expert, so let me know if it's something else. Once I get the servo's repaired, I'm considering the following Green Accents: Powder Coat Frame, Wheels, Anodized Aluminum Servo Horns, Anodize Aluminum Air Cleaner. This has been a fun project so far, I'm very impressed with the chain drive, Aluminum roll cage and suspension.
Thanks Limestang
Gone fishing
- limestang
Kyosho Fans - i thought you might like seeing the Silver Fox after restoration photo's. I upgraded to gold shocks, so decided to keep the theme going with the frame. Other new parts include: Servo links, tires, chrome brackets, air filter assembly, muffler and gas tank. Everything was cleaned, and assembled wtih stainless screws . The engine was gummed up, but now turns freely with great compression. From what I can see, this buggy did not see much run time.
- 988 Views
Last post by infamous
- 1633 Views
Last post by klavy69
- 1506 Views
Last post by Asso_man!
- 414 Views
Last post by Dangeruss
- 2505 Views
Last post by cooltoys
- 1391 Views
Last post by RC10Eh
- 1055 Views
Last post by limestang
- 3290 Views
Users browsing this forum: Mojeek [Bot] and 4 guests
