Kyosho Vanning Shock Collar Solution
limestang
Has thanked: 100 times
Been thanked: 249 times
Post by limestang »
I thought I would pass this on. The factory shock collars on the Vanning are plastic and become brittle with age. I took a chance, and purchased a pair of these aluminum ones. They work great and the red color makes for a good factory appearance. They are available on Ebay, but you can save a little bit of money by going to partgustore directly. Hope this helps.
-Limestang
10mm shock clamps.jpg (11.61 KiB) Viewed 1055 times
highwayracer
Been thanked: 6 times
Re: Kyosho Vanning Shock Collar Solution
Post by highwayracer »
For the front shocks, you can also use the collars from the Raider. The plastic is more like nylon and it will not break or fade like the originals.
limestang
Post by limestang »
Very cool - Thanks!
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarBing [Bot] and 3 guests
