FARMERS Official ORANGE RACER Build it is DONE 8/27/12
Well guys after weeks of collecting and waiting for parts
i have enough parts to officially start my Orange Racer
ya there is some parts that i still have to hunt down
the MIP change box is work in progress
but i will make it work
once again this will be no shelf queen
its going to be a runner
so here we go
enjoy farmer
ya i know the shock screws are long
ill cut them later
so here we go
enjoy farmer
ill cut them later
Re: FARMERS Official ORANGE RACER Build Thread
i am really liking the way that this build is going. Is the chaissis powdercoated or painted?
Keep going and post progress!
LOSI LOVER!
Who makes the aluminum(?) upper shock pivots that you have on the front and rear tower?
- Has thanked: 36 times
- Been thanked: 1318 times
Ya its paint
multiple primer coats sand coat sand coat repeat to fill im blemishes
same with paint, but no wet sand till the last coat
than about 3 coats of auto clear
thx farmer
thx farmer
I couldn't figure figure for the life of me how to get the shock away from the tower without using multiple washers or bore washers. and as it turns out - all along while I was searching for "shock mount", "shock pivot", "shock anything!".scr8p wrote:associated
Shock STANDOFF!
thank you scr8p!
& farmer for posting detailed pics!
jb
Ok once again im waiting on some parts namely! one specific bearing!
but i have a question for all the people that are useing the jeepz arms
what size turn buckles u guys useing
reggie said something about 46 to 48 mm x 4 i imagine thats the fronts, and 40 to 42 mm x2 which i think would be for the rears but i belive he was talking about klien arms, so if some one could measure the top and bottom fronts and the one rear without the cups on thx
i will be useing the standard rpm cups
also has anyone did the 12mm hex front conversion if so what parts did you use?
i have some ideals
also i from what i have tried to find info on
inline steering cant happen with 12mm conversion
other words if you/i want inline steering you have to use rim captured bearings
is this wrong?
thx for the help
farmer
i have some ideals
is this wrong?
thx for the help
farmer
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
I haven't done it but this is what you need:
Steering block: ASC9880
Axle: ASC7496
Hex: ASC7497
Caster block are the usual B4 parts. Bearings are 3/16 x 3/8 plain. Hinge pin for the steering block is the usual B4 pin...the one to attach the c-block to the arm is the standard RC10 pin but the hole in the B4 c-block has to be enlarged to 1/8".
Axle: ASC7496
Hex: ASC7497
thx phin those were the same part # i got
i was just reading where some people were using sc10 steering blocks
anyone help on the tie rod sizes?
thx farmer
thx farmer
- nvxwax
Thats a sweet build farmer, I have a question lol, What would converting to hex in the front give ya? I know for the DS cars its to use modern touring car wheels, but im kinda at a loss with a buggy lol.
Is there some cool hex wheels i dont know about?
- flipwils11
- Been thanked: 19 times
Really cool, I love the orange and has the same idea for one of mine in fact but I was going to try to find orange anodizing if possible. Now you beat me to it with the color combo you picked!
The reason for the hex my 2cents worth
Is 1 no rim captured bearings I've never been keen
On bearings not only carring the duty of the rotation
Of the wheel but also the stress of side to side rim flex/stress
Also with the movement of all the major rc players
Moving to a hex style of rim . I want the availability of rim where ever I go if
So needed
Also doesn't hurt that it's a lot Easter to try a tire that someone
Else has
Aghhh cell phone reply will go into more depth later
So needed
Else has
- nvxwax
Thats a good reason, I have never seen any hex fronts for buggys lol, But i dont get out much lolfarmer wrote:The reason for the hex my 2cents worth
So needed
Else has
- soniccj5
Rebuilding my Whats old is new using Bigjeepzz arms and went with a set of B4 turnbuckles. I just cut them down.
EDIT:added photo.
EDIT:added photo.
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
I used Lunsford turnbuckles with RPM ball ends on my Old/New build. I'm pretty sure I used the sizes below:
1 1/2" for the front upper link w/ B4 carriers
1 7/8 for the steering
1 3/4 for the rear
The steering one is for an A&L system, so this might need to be longer for other steering systems (Houge, stock, MIP, etc.)
1 3/4 for the rear
- 2848 Views
Last post by DennisM
- 1499 Views
Last post by farmer
- 28 Replies
- 3047 Views
Last post by askbob
- 23 Replies
- 2556 Views
Last post by askbob
- 124 Replies
- 16454 Views
Last post by JK Racing
- 2113 Views
Last post by pumpkinfish
- 27 Replies
- 5562 Views
- 1579 Views
Last post by mikea96
Google Adsense [Bot] and 6 guests
