Or am I better off with the Thunder Tiger Phoenix ST wheels: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXALEP&P=7 and http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXALKH&P=7
You could, but not much point, since the 1/4" and 3/16" pinned style is still supported by AE and aftermarket. If you can find 1/4 wheels you like, run the universals. Otherwise, just pick up a set of T/T2/GT CVDs and 3/16" x 3/8" bearing, and run 3/16" wheels.Am I able to get plastic hexes from the T4 and ream them out on the back side to fit so I can run the newer hex wheels? I f i can do that, should I convert the front wheels to hex's also?
