whats up guys
im building my MIP change box for my orange build and i ran into a problem
when i get to the ball diff as per instructions the stealth balls are to small keep falling through the holes the 3/32 balls are to small!
the instructions
it says use the mip change box by simply rebuild the change box with the stealth diff parts
i does not say anything about larger diff balls
em i missing something
any help
thx farmer
MIP change box help
- Has thanked: 36 times
- Been thanked: 1318 times
Re: MIP change box help
put the diff gear on one of the outdrives first, then put the the diff balls in. they won't fall out then.
I did try that scr8p it just didnt seem rite
but ill build it that way kinda weird
thx farmer
thx farmer
Just remember you can't put too much lube in them when building. Just wipe the excess off when done.
well i built it and man there is gear rubbing all of the box
b4 top shaft will not work YET case hole is to small b4 top shaft has a bigger dia shaft by the gear
has anyone have the gear rubbing the cas prob? almost feels like the gears are to big for the case?
farmer
farmer
- 1706 Views
Last post by aconsola
- 1569 Views
Last post by CoalTrain
- 2256 Views
Last post by LoboNYC
- 2095 Views
Last post by hugger19
- 836 Views
Last post by Halgar
- 1713 Views
Last post by Lowgear
- 3107 Views
- 1065 Views
Users browsing this forum: Ahrefs [Bot] and 7 guests
