RPM arms questions??????????????
General info, Q&A.
Dr. Robotnik
Post by Dr. Robotnik »
Hi RPM heads,
My question today is can I fit narrow arms as seen on Asso-man's amazing CC chassis,
To either of my tub cars (I can handle a little drilling and chassis cutting)
Any help would be much appreciated, and if anyone could say what the Pink tub is drilled for already that'd be great too 8)
cheers
Ed
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Re: RPM arms questions??????????????
Post by Asso_man! »
Ed,
You can of course mount those RPM long arms to any of your chassies, RPM included in their rear arms conversion kits a template to drill the two additional holes needed at the rear, just behind the bulkhead. You will also need to trim the chassis on both sides to accept travelling of the rear arms.
Your pink chassy is drilled and countersunk for both the 6 gear and the Stealth trannies...
Cheers
David
Come and visit the stable
Dr. Robotnik
Wow thanks for all the info, David!!! I was just worried as the chassis would have to be narrowed that some of the holes might get in the way...
You see I bought the Pink chassis to do an RPM front end and in a parts lot spotted I had the RPM rear arm mounts, then spotted Tulsa had the narrow chassis RPM rear arms for sale so things are spiralling out of control as per usual....
Cheers
Ed
Asso_man!
Post by Asso_man! »
If you need the template I can scan it for you. Also, check out didou's sales in the BST, he also has some NIP white RPM rear arms and other bits :wink:
Dr. Robotnik
Wow, thanks, yes I believe I would need the template if you can find time to scan and email it to me, though there is absolutely no rush as I only won these items last night!
Hehehe off I go to the BST section.... 8)
