AE 10L question.
AE 10L question.
I am getting a 10L from a member on here and I was wondering if there are different rear hubs that I can put on it to use modern wheels.
Could anyone shed some light on this? I'd appreciate it!
- Ivan Dobsky
Re: AE 10L question.
What "modern wheels" do you mean? 1/10th scale pan car rims have not changed in a long time. Do you mean GT wheel adaptors to put touring car rims on? or some other kind of rubber tire? Its a difficult question to answer without knowing exactly what kind of wheels you plan on fitting.
The 4 hole pan car wheels. Like the CRC track magnets.
I know some of them were 2 hole, and 3 hole. I get the track magnets local, because CRC is 2 miles from me.
- Ivan Dobsky
If the car has the original hubs fitted to it then any modern 1/10th pan car rims will fit, including the current CRC range.
Same goes with most 4-hole or 2-hole aftermarket hubs.
Put simply its very unlikely you'll have any problems unless your car has some freaky weird hubs.
I hope this helps.
I hope this helps.
I think those are the hubs on my car. I getting it from njdriver04 on here. I saw some rc12's on ebay that the rear tires looked like they were secured with a nut. I was a little "gun-shy" about them.
Hows the parts availability for these cars? Can they still be competitive with today's 12 scale cars?
A quick way to distinguish between 10th scale and 12th scale rear wheels is that the majority of the 10th scale wheels have a four hole mounting pattern were the 12th scale cars have a three hole mounting pattern. However, some of the 10th scale wheel do have two hole mounting pattern, but those are usually custom alloy wheels.
R_
R_
Thanks for the info. I'm just getting into carpet racing. I'm just trying to get some info so I can get some spare parts and try to modernize it a little.
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
- drbelleville
- Been thanked: 4 times
Good source for hubs is CRC, and Irrgang, they should still have a complete setup, that will allow you to run 3 bolt wheels. Also check here and the bay, a complete RC12L3 axle with hubs pops up every now and then.
- 1089 Views
- 1667 Views
Last post by Phin
- 2751 Views
- 889 Views
- 1145 Views
Last post by knucklebuster
- 779 Views
Last post by JosephS
- 1423 Views
Last post by drbelleville
- 979 Views
Last post by lukin
