In the wide car, wide pod, the rear looks like a go kart lol. I have swapped around some hubs but the rears appear to be correct. I know the rubber caps make it look a little off, but the hubs are centred in the chassis.
Any ideas?
SS has a narrow axle and narrow diff hub. The narrow diff hub has the outer bearing (closest to wheel) flush with the outer edge of the hub IIRC, while the outer bearing is recessed on the long diff hub. I think the left hubs are the same width.gomachv wrote:Yeah and its pretty pristine![]()
Its narrow but not a SS (from what I can tell) because of the front track and looks like it should have had a wide pod but maybe that's my real issue. A narrow pod would be great on it, especially with those caps. They have some offset to them. I will slap on some standard tires and measure them up
As far as right side hub, should a SS have a narrow or wide hub and axle? All my axles are set up for that long hub, and without more than a small shim the right side hubs fit with the correct widths to match.
