Is acetone safe to use on white plastic parts?
Is acetone safe to use on white plastic parts? I have a white stealth tranny case and a white rear bulkhead that have what appears to be CA glue on them. I've read about using acetone to remove the glue from old, worn out tires and plastic wheels. Can I use this method to remove the glue from my parts? Thanks in advance for your replies.
- ROH73
- Been thanked: 23 times
Re: Is acetone safe to use on white plastic parts?
Plastic is a generic term referring to any number (thousands) of polymer materials. So, acetone is safe for some plastics and not for others. White and black AE molded parts are made from nylon 6/6 and acetone is safe to use on nylon. It will take the CA glue off with no problems.
Examples of plastics that acetone is not compatible with are polystyrene (white molded Tamiya bodies), lexan and ABS (black Tamiya chassis).
- Been thanked: 325 times
Acetone will eat plastic, but would be fine on nylon. I used acetone to remove paint from some old Marui Galaxy wheels, which are cheap plastic, and it ate at the plastic.
Thank you so much guys for the info. I will grab some acetone and clean these parts up.
- bearrickster
its called different thing depends on were you are, but for cleaning parts Purple Power, Castrol Super Clean? same stuff different names works great and doesnt eat most parts. just no Plastic with Chrome on it.unclemikey1978 wrote:Thank you so much guys for the info. I will grab some acetone and clean these parts up.
- 3204 Views
Last post by DerbyDan
- 1369 Views
Last post by 85Edinger
- 994 Views
Last post by hobbes
- 1135 Views
Last post by Eau Rouge
- 686 Views
Last post by XLR8
- 1070 Views
Last post by Bimdapogs
- 2408 Views
Last post by Prince Steve
- 1298 Views
Last post by Grumbles
