White plastic
General info, Q&A.
pink_sleeve
White plastic
Post by pink_sleeve »
What is the best method you guys have found to freshen up the looks of the white plastic parts?
LowClassCC
Has thanked: 108 times
Been thanked: 171 times
Re: White plastic
Post by LowClassCC »
simple green is the most cost effective i have used and i think it will be what most will say to use. this is the way i would say to go about cleaning parts.
i have also used brake cleaner with good luck. but a can don't do very much and is most likely one of the least cost effective ways to do it. also note that brake cleaner can not be used on all plastics. so test it out on a part you can afford to destroy.
other things i have tried which didn't do any better than simple green were: soft scrub, bleach, misc cleaners with bleach, oxy, purple stuff, ect.
pink_sleeve
Re: White plastic
Simple green it is then. Thanks
Has thanked: 357 times
Been thanked: 470 times
Re: White plastic
Purple power and heavy degreasers can "tint" some of the nlyon, Oxyclean is always a safe bet
........and if you can do it outdoors...........Boiling bleach bath 50/50 works great to open the pores in the nylon and whiten up
Obsessed
Re: White plastic
Post by Obsessed »
Rit (Rit Dye) makes some color remover and some whitener products. I've used that in the past and it worked very well. Boil the parts in a bath of Rit. Make sure you have good ventilation or your wife will complain.....I know that from experience. It smells terrible.
Grumbles
Re: White plastic
Post by Grumbles »
Guy's thanks for sharing! I really need try some of these out. 1 question though... approximately how long do you boil your parts in the bleach bath?
Users browsing this forum: No User AvatarAmazon [Bot], No User AvatarGoogle Adsense [Bot] and 4 guests
