RC10 Ball Cups?
RC10 Ball Cups?
Will these things fit my RC10 buggy? http://www.ebay.com/itm/RPM-73381-HEAVY-DUTY-WHITE-4-40-ROD-ENDS-BALL-CUPS-RC10-/270835568070?pt=Radio_Control_Parts_Accessories&hash=item3f0f0ecdc6
I replaced the shock tower today and got to noticing that it has 3 ball cups that are much bigger then rest and one rubs against another on my steering. I would just like to replace them all. Are those on eBay any good and will they work ok for my buggy?
RC10talk.com is like a bad accident, I just can't stop looking at it...
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: RC10 Ball Cups?
They'll work but if you put all rpm cups together in the steering area they will rub yet. I've seen alot of guys use stock cups on the inside top turnbuckles and they pass without rubbing but otherwise yep...they'll work for your rc10
Re: RC10 Ball Cups?
Yeah I see what you are saying, the ones that I have rubbing, one is stock and the other is a heavy duty model and they still don't seem to work to well together. Maybe I'll just replace the rest of them and use all stock cups around my steering to solve that problem. Thanks for the help...klavy69 wrote:They'll work but if you put all rpm cups together in the steering area they will rub yet. I've seen alot of guys use stock cups on the inside top turnbuckles and they pass without rubbing but otherwise yep...they'll work for your rc10
Re: RC10 Ball Cups?
Associated makes a ball stud with a short "neck" If you use these on the tower, it will reduce/eliminate this issue. -Jeff
Re: RC10 Ball Cups?
Well maybe I will look into finding a few of those and see how it works out and thanks for the info...Jay Dub wrote:Associated makes a ball stud with a short "neck" If you use these on the tower, it will reduce/eliminate this issue. -Jeff
Re: RC10 Ball Cups?
Did you use your original turnbuckles with these cups? I have to repair a cup on my graphite rc10 and wondered if I could use my original turnbuckles...thanks.
- 140 Views
Last post by TravelinTravis
- 1399 Views
Last post by DrumAnBass
- 2095 Views
Last post by R Cane
- 762 Views
Last post by frgna
- 2170 Views
- 912 Views
- 1165 Views
Last post by JosephS
- 2213 Views
Last post by bully
Users browsing this forum: Tbot [Bot] and 5 guests
