air brushing
Norman
air brushing
Post by Norman »
I had a quick question about airbrushing. I have been looking at compressors and i want to get one that can do 2 things. one is airbrush and the other for just blowing off the car when its dirty.
You think this compressor would work
http://www.harborfreight.com/3-gallon-100-psi-oilless-pancake-air-compressor-95275.html
thanks.
Hi. :)
littleVETTE
Has thanked: 6 times
Been thanked: 10 times
Re: air brushing
Post by littleVETTE »
looks pretty good for the price. make sure you buy the extended warranty.
Jayar
Re: air brushing
Post by Jayar »
Yes it will work, Airbrushing uses 15 to 30 psi so it will keep up, and blowing off you rc will only take a moment.
It would suck at jobs that use higher psi and ones that require high pressure for lengthy periods.
When they ask you if you want an extended warrenty ask them "why is there something wrong with it" and watch the look on there face and if it last more than a month it will probably keep on working if you take care of it.
If you have problems with it take it back right away they usually will refund your money.
Gotta go shameles is just about on tv.
bye
J.R.
Users browsing this forum: No User AvatarAmazon [Bot] and 4 guests
