My first attempt with an air brush
jkelm24
Has thanked: 34 times
Been thanked: 80 times
Post by jkelm24 »
I thought I'd start with something easy for my first attempt with an air brush. The Dyna Storm was perfect for the job!
I used liquid mask and Faskolor water based paint. The air brush was used for the liquid mask. It took about four good coats to build up enough to allow for a good score and peel. Maybe I'll try brushing next time to see the difference...
I didn't want to spend extra money for a hobby compressor, so I just used my shop compressor at 50 psi... :lol:
I can't imagine ever rattle canning a body again! Water based paint with an air brush was awesome! No nasty vapor, easy cleanup, and much easier to navigate the inner angles of the body with a small air brush.
CruzinCustomz
Been thanked: 10 times
Re: My first attempt with an air brush
Post by CruzinCustomz »
Nice, how durable is the Faskolor paint, does it scratch easy?
jkelm24
Post by jkelm24 »
It will scratch if you try hard enough. I backed mine with a single coat of black poly lacquer to seal it.
If you're interested, there are several posts on this forum that outline the general process and provide great tips!
Sorry for the bad pictures. I'll get some better pictures in the future and add them to my Dyna Storm build thread.
JamieB
Post by JamieB »
Nice job, what airbrush are you using?
duckhead
Has thanked: 162 times
Been thanked: 205 times
Post by duckhead »
Looks good!
I have been wanting to try my hand at airbrushing as well so thanks for posting this, I was curious about the water based paints and how well they adhere to the bodies. Sounds like backing it with something else helps create the bond to seal everything together.
Interested in what airbrush you used as well.
Keep at it and keep posting your work :mrgreen:
jkelm24
Post by jkelm24 »
I just used an inexpensive $30 dollar Central Pneumatic airbrush. I didn't want to invest in an expensive brush and compressor until I figured out what I was doing. It's perfect for basic solid-color paint schemes.
JamieB
Post by JamieB »
Just looked on Amazon, £76 in the UK. Typical we get over charged :lol:
An airbrush is on my wish list so thanks for letting us know. Be good to see some more of your work as it comes along. Good luck.
snowfox
Has thanked: 10 times
Post by snowfox »
Yeah this is cool, been tempted for a while but was put off as I have limited space and adequate ventilation. Water based paints which don't require ventilation? Sounds great!
Keep the paint schemes coming!
Give it Gas!
RC104ever
Post by RC104ever »
Do you dilute the paint with anything or just use it right out of the bottle?
- Chris
Lots of cars...so many cars
RCveteran
Has thanked: 26 times
Been thanked: 200 times
Post by RCveteran »
What tires are in that sweet JrX2 bag? :lol:
integra22t
Post by integra22t »
just dont mix up the oil and paint jars lol
jkelm24 wrote:I just used an inexpensive $30 dollar Central Pneumatic airbrush. I didn't want to invest in an expensive brush and compressor until I figured out what I was doing. It's perfect for basic solid-color paint schemes.
That is my suggestion too. I got a couple $20 HobbyKing airbrushes and they work just fine for basic paint jobs. What they lack, however, is the fine tip spray controllability that you want for fades or detail work; they clog up too easily, especially with metallics or pearls. I'm going to have to invest in a better-quality airbrush for those detail tasks.
