Alternative For 2" Buggy Rear Tires
LTO_Dave
Has thanked: 52 times
Been thanked: 287 times
Post by LTO_Dave »
Since it seems like the world has moved forward to nothing but 2.2" wheels and tires for buggies, I needed to find some readily-available 2" rear tires to keep my RC10 running.
I had a pair of Losi LOSB0982 Mini-Kingpins for an 1/18 Mini LST that I was trying to sell for my friend. After removing my nearly-bald AE TQ-20's, I put the Losi tires and foams on my 2" rear wheels and they fit like a glove. :mrgreen:
So this opens up a world of possibilities since these tires are still available...and they're cheaper than 1/10 2" rear tires.
THUNDERSTRIKE1
Re: Alternative For 2" Buggy Rear Tires
Post by THUNDERSTRIKE1 »
AWSUME DUDE great find lol.But what size are the 1/18th tires?That way know getn the right ones.DON
Excellent work sir!!!
LTO_Dave
Post by LTO_Dave »
THUNDERSTRIKE1 wrote:AWSUME DUDE great find lol.But what size are the 1/18th tires?That way know getn the right ones.DON
The outside diameter of the Mini-Kingpins is about 3 1/8" and the width is about 1 3/4". :wink:
THUNDERSTRIKE1
So no size on the 18th tire packaging huh ?Thanks Don
Nice, those would maybe work on vintage Kyosho rims too, the outside diameter is good...but they're just about a quarter-inch too wide, so that might pose a problem for some rims. Most Kyosho rims take tires that are 35 to 39mm or so wide, while these are almost 45mm. I don't suppose you have a Kyosho wheel to try this out on?
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
I've been wanting to try the tires from the 1/14 Losi Mini 8ight buggy but Losi doesn't seem to sell the tires separate from the wheels...though you can buy the wheels without the tires :?: :roll:
Supposedly the Mini 8ight wheels are the same diameter as standard touring car wheels.
LTO_Dave
Post by LTO_Dave »
THUNDERSTRIKE1 wrote:So no size on the 18th tire packaging huh ?Thanks Don
What dimensions are you looking for? I don't have any 1/18 wheels to measure if that's what you need.
Coelacanth wrote:Nice, those would maybe work on vintage Kyosho rims too, the outside diameter is good...but they're just about a quarter-inch too wide, so that might pose a problem for some rims. Most Kyosho rims take tires that are 35 to 39mm or so wide, while these are almost 45mm. I don't suppose you have a Kyosho wheel to try this out on?
Here ya go. :wink: I mounted one on my Slingshot wide rear wheel and it fits. The two wheel halves need to be pressed together a little which causes the tire to baloon slightly, but nothing major. I didn't try one on a narrow front wheel, but I think it would be balooned even more than the rears and may look goofy.
Looks like a pretty good fit, thanks for that test. Nowadays, I swap out the Kyosho tire inner plastic rings for foams, I find they make the tire more consistently firmer than those flat rings did, and might help spread out the tire to make it less rounded, too.
So, I wonder if other tires for the Mini-LST and LST2 would fit the same way, such as LOSB0981 or LOSB0984? I like the aggressive tread patterns on those. The second one might even work quite well in loose dirt & sand.
Losi LOSB0984 Tires.jpg (77.81 KiB) Viewed 1387 times
Losi LOSB0981 Tires.jpg (19.92 KiB) Viewed 1387 times
RC104ever
Post by RC104ever »
Here is my contribution to oem tire options:
http://www.rc10talk.com/viewtopic.php?f=38&t=22274
- Chris
Lots of cars...so many cars
Users browsing this forum: User avatarjuicedcoupe, User avatarscr8p, User avatarXLR8 and 4 guests
