Countersunk hole clean out
- rc10johnny
Hey Guys, I just got some powdercoat back from LTO and was wondering which flute to use to clean out the powder? Thanks JohnnySr
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
- LTO_Dave
- Has thanked: 52 times
- Been thanked: 287 times
Re: Countersunk hole clean out
Will the 5 or 6-flute bits work ok on aluminum when using a drill press or should they be used in a CNC or lathe?
I have the 3-flute bits from McMaster and the results aren't that pretty when using them on aluminum in a drill press. Will faster or slower speeds give better results or doesn't it matter?
any flutes will work with any material. SFM, surface feet per minute, needs to be taken into account, which varies for a given material. 5 or 6 flute should give you a better finish. You might try bumping up the speed on the drill press with a 3 flute and try again, it's also possible the material might want a slower one also. A dull one could also cause some rough finish.
- rc10johnny
well since my move all I have left is a hand drill
no more drill press......
- 912 Views
Last post by askbob
- 979 Views
Last post by MarkyDents
- 1626 Views
- 1204 Views
Last post by Minicooper 35
- 1317 Views
Last post by slotcarrod
- 1290 Views
Last post by bearrickster
- 615 Views
Last post by transamman908
- 718 Views
Last post by muck
