I just mounted up my front suspension with Klein arms and the longer GT front shaft. My stock RC10 inner hinge pin mount was too narrow for the Klein arm so I used a spacer (about 1/4" thick).
What is the correct hinge pin mount to go with the front Klein arm?
Klein Arms front mount question....
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
Re: Klein Arms front mount question....
for the klein front arms you need rc10t nose plate, bulkhead, and hinge pins. the stock rc10 nose plate is too wide and the mounts/hinge pins are too small for the klein arms.
- soniccj5
Check my reply to the same question in the post below.
http://www.rc10talk.com/viewtopic.php?f=38&t=25150&start=15
- 799 Views
Last post by mikea96
- 595 Views
Last post by THUNDERSTRIKE1
- 22 Replies
- 4577 Views
Last post by mdutcher
- 822 Views
Last post by surgetek
- 791 Views
Last post by Caine
- 1962 Views
Last post by Mikeyboy
- 781 Views
Last post by cautrell05
- 1267 Views
