Intro and question about B2 wheels
JollyGreen
Post by JollyGreen »
Hey all, I have my B2 I built in 98, and I have only managed to break two parts in 13 years, so my car is pretty original. I did recently put in a brushless motor/esc to make it friendlier to use. I am a basher only. This is due to the fact that I live in a black hole of tracks. There is one indoor track about 30 minutes away, but it is small (5 turns) and they want $20 to race ($10 to practice, but it is packed). So my questions will be related to making my car look better and be able to use some newer equipment, which leads me into my question.
I really want to put these wheels on my b2. I think they look pretty cool, and they can handle asphalt (half my time is spent in the parking lot at work).
http://www.amainhobbies.com/product_info.php/cPath/1_26_213/products_id/5511/n/Pro-Line-Dirt-Hawg-I-22-Buggy-Tires-2
The cars hubs, axles, etc. are all original, so are there any 2.2" wheels that will just fit? or do i need to change out the hubs, so i can use any modern wheel? If so what parts will be needed? Has anyone done this and can give me first person advice?
And, I do realize i will need to lower the gearing since the wheels are bigger so i dont run hot.
thanks, and I hope to learn enough from tinkering, that I can someday contribute something to this board.
Re: Intro and question about B2 wheels
JollyGreen
So if I get those wheels, and some foam, they will slap right on??
thanks for the reply scr8p!
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
yep, those wheels scr8p mentioned and your tires you mentioned and they will slap right on. You'll be good to go.
teman
Been thanked: 6 times
Post by teman »
I have a full set of these for the B3's, great for the road and in my case great in the MUDD :lol:
-Kevin
Bugle
Post by Bugle »
The exception is if it's a B2 Sport which came with the old 1/4" dogbone axles, and bushes, yuck.
rctenracer
Been thanked: 81 times
Post by rctenracer »
Bugle wrote:The exception is if it's a B2 Sport which came with the old 1/4" dogbone axles, and bushes, yuck.
If you have the sport and want to change to 3/16 axles . Thunder tiger cvds Part# PD9000 are your best bet for a change over.
flipwils11
Been thanked: 19 times
Post by flipwils11 »
Or if you want to spend more, the MIP shiny CVD's for the B3 which are still around if you look for them.
JollyGreen
As luck would have it, I have the B2sport....
So is this what I need?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAKRJ&P=7
or this?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAV59&P=M
i think those thunder tiger ones will fit. the mip kit is for 1/4" axles which is what you alreasdy have.
99.9% sure these will work too.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNTL6&P=SM
PBR Allstar
Post by PBR Allstar »
scr8p wrote:i think those thunder tiger ones will fit. the mip kit is for 1/4" axles which is what you alreasdy have.
I'll add the .1% for you scr8p, they work.
dont forget bearings with 3/16" I.D.
rctenracer
They are also a little longer than the MIP cvd and fit into the outdrives better.
JollyGreen
Ok, Thank you one and all for your help...
to review... I will need the custom works CVD kit, bearings that have an O.D. of 3/8" (measured them just now) and an I.D. of 3/16".
So, will almost any 1/10 buggy wheel work or is there still more to it?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSXR7&P=SM
these are what i have modified to fit on there now, but I would like to do it right this time.
thank you.
teman
Post by teman »
B3 wheels, Thunder Tiger Phoenix & the JC Racing B3's, there might be some others like Losi not sure which though. B4's don't really work, the offset makes it too narrow. On those front DH3 tires, they'll work better with the wide front wheels as opposed to the normal fronts.
-Kevin
Users browsing this forum: No User AvatarAhrefs [Bot] and 5 guests
