I've done a lot of searching, but can't seem to find a good answer to this question.
I am upgrading my RC10T that has a stock Stealth (but now with a b4 slipper setup) to a Tacon 11T 3200kv brushless setup, using a Hobbywing Xerun 60a ESC. Any thoughts on where to begin with gearing? I am running 87T spur with 18T pinion on my mild modified brushed setup currently, but I dont think that kind of ratio (4.83) is recommended for brushless.
Is there a good target ratio I should be moving to with this kind of brushless setup?
Thanks everybody!
Brushless gearing question (Tacon 3200kv)
Re: Brushless gearing question (Tacon 3200kv)
I can tell you that on my 10T using the Tacon 2950KV and a 35A Hobbywing ESC with 2s Gens Ace lipo, I'm geared at 81/26. The motor and ESC never get hot after a 8min. main. It has tons of torque and accelerates to nearly 40mph on the straights in a 1/8 scale track. I generally lower the timing from 0 to 15 degrees max.
In Christ,
Joel C.
Joel C.
- 1405 Views
Last post by pmathews924
- 854 Views
Last post by Rustbucket
- 2392 Views
Last post by MOmo
- 9615 Views
Last post by kiohio
- 933 Views
Last post by Bmw1tech
- 2027 Views
Last post by Stumpy
- 1948 Views
Last post by daz_75
- 20 Replies
- 3651 Views
Last post by tecnica2001
Users browsing this forum: No registered users and 16 guests
