Faskolor fluoresent help.
- Been thanked: 81 times
Whats up with this paint. Thin coats with the airbrush drying with a heat gun between coats. The paint is pealing up with the tape after two coats. Peel when wet or score with the #11 blade ? Any help?
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
Re: Faskolor fluoresent help.
i use the orange on my builds and hate it. yet for some reason i keep using it. i always score the edge of the paint next to the tape before pulling off the tape. this help prevent the paint from pealing. also i have found even with using a heat gun to help dry to take time and wait until the next day to peal the tape. most of the time i can't bring myself to wait that long though.
- SoloGraphix
I try VERY hard to paint flourescents last, not only does it eliminate the mask issues, but when you back it with white the whole body can get a nice white interior coat. I know that preparing the colors in the right order is sometimes impossible, we just have to do our best.
- extreemduster340
A tip when using water based paint----air flow helps more then heat to dry this paint. If its cold out you will have to add heat but remember the air flow!
- 3718 Views
Last post by PBR Allstar
- 1207 Views
Last post by Constant
- 915 Views
Last post by rctenracer
- 1187 Views
Last post by integra22t
- 36 Replies
- 9879 Views
Last post by charlie_b
- 1708 Views
Last post by works92
- 1067 Views
