FasKolor FasFluorescent: UV-reactive?
- Been thanked: 325 times
Hi Guys,
Does anyone know if FasKolor FasFluorescent paints are UV-reactive? Do they glow or illuminate when under a blacklight?
I'm building an AFX slot car track and I want each lane's outside turn guardrails, which I'm making from Lexan, color-coded red & blue. I have several cars with lights and for "night racing", I thought it would be cool to have the guardrails glow under a blacklight. I plan to use FasFluorescent Blue & Red.
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
Re: FasKolor FasFluorescent: UV-reactive?
Under a blacklight the Orange, Yellow, and Green glow very nicely. I can not speak for the other colors though.
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
I am not sure about Parma paint but I have used luminescent paint with uv lights for a "star light " ceiling in my theater. I used Glowinc brand.
It glows fairly bright blue under uv and will remaining glowing for about an hour.
When it comes to luminescent paint green is the brightest followed by blue-green,blue and to a less extent red.
Thicker application is brighter and glows longer. Painting on a white background helps as well.
Lots of companies out there on the net make luminescent paint and as I remember some made fluorescent paint also.
Chuck
Chuck
Thanks for the info, guys. I'm looking for a UV-reactive, not glow-in-the-dark effect; i.e., it looks like light blue or red in normal light, but under blacklight, it glows. I believe the glow-in-the-dark effect is different in that it "stores" normal light, and when the lights are off, they glow with that pale greenish light. Not looking for that kind.
Back in my computer modding days, I used ClearNeon spray paint which was excellent stuff, it sprayed on clear but under UV light, it glowed. I'm not sure how well it adheres to Lexan, though...and secondly, I want the guardrails to be colored red or blue in normal daylight to indicate the lane with outside curves...but flick on a blacklight and all the guardrails will glow red or blue. If the FasFluorescent paints do this, it's hitting two birds with one stone and no need to experiment with layering on different kinds of paint.
- works92
- Has thanked: 85 times
- Been thanked: 32 times
Sorry I doesn't read well what you looking for.
Createx make a UV reactive base
https://createxcolors.com/wicked-airbrush-colors/wicked-fluorescent-peralized-colors/w210.html
I suppose you can combine it with fasfluorescent without any troubles
- 3700 Views
Last post by PBR Allstar
- 1203 Views
Last post by Constant
- 986 Views
Last post by extreemduster340
- 909 Views
Last post by rctenracer
- 1186 Views
Last post by integra22t
- 36 Replies
- 9872 Views
Last post by charlie_b
- 1065 Views
