RC10 Battery too long
limestang
Has thanked: 100 times
Been thanked: 249 times
Post by limestang »
Hello all, I am rebuilding a mid 80's RC10 with used parts so that I can drive it again. My goal is to keep it stock, including the resistor style speed control. I am having trouble finding a battery that fits in the stock holders, the one's i have tried are too long. The battery needs to be in the sideways orientation. I have heard that over time the sub-c batteries have grown in size. Any recommendations on a suitable replacement? I would prefer the pack pre-assembled, but will build one if needed. Thanks Limestang
slim_chance
Re: RC10 Battery too long
Post by slim_chance »
I haven't tested it yet but I will in the morning. I think a side by side battery set up may work. I will put one of my matched cells packs in to mine and see what happens. Do you have the battery set up that runs up the middle or from side to side?
Super phenominal cosmic plans! itty bitty bank account.
Procrastinators unite!......tomorrow.
My new Fb page by bashers for bashers. Rc bashers unite! http://www.facebook.com/RcBashersUnite
limestang
Post by limestang »
With the Resistor speed control, I am limited to side to side. Thanks for your help.
AndrewSi
Post by AndrewSi »
cut the end off the battery pack so you can remove the bulky plastic cover(the side without the wires). I have a couple batt packs that are like this for this very reason.
Jay Dub
Post by Jay Dub »
Usually, one would drill two new holes for the battery cup, and move the cup forward a 1/4" or so. Thais also allows for centering of the chassis as most of the original chassis were mis-drilled from the factory. -Jeff
madweazl
Post by madweazl »
Jay Dub wrote:Usually, one would drill two new holes for the battery cup, and move the cup forward a 1/4" or so. Thais also allows for centering of the chassis as most of the original chassis were mis-drilled from the factory. -Jeff
He wants to retain the manual speed control so the battery needs to remain in the stock orientation. I ran into the same problem with mine; since it isnt driven, I removed the shrink wrap and plastic ends from the pack and was able to squeeze it in there.
slim_chance
Ok both of mine are center mounted and the end of the graphite's battery cup was already cut off to fit stick packs when I got it
limestang
Post by limestang »
Thanks all for the ideas. I will try modifying one of my older battery backs. Madweazl - I took a double take when I saw your RC10, I have the same radio system:)
madweazl
Post by madweazl »
I got 2 or 3 in various trades. I never had an RC10 or Aitronics radio back in the (I was Losi and Futaba faithful :lol: ) so I figured they belonged together.
limestang
Post by limestang »
I figured out a pretty easy fix for this problem. I trimmed off the ends of the two battery cups. A standard 7.2V stick cell from Tower hobby fits snugly against the sides of the chassis. Very easy to implement - I recommend using ugly used parts so you don't feel bad about cutting vintage RC10 parts:)
