Airtronics 94156 servo info?
Picked up a T2 that had an Airtronics 94156 servo in it. Anyone know roughly how old that is or have any specs for it? Found it mentioned online, but no detailed info. I'd like to know if it's period correct for the T2, or whether it belongs elsewhere (or in the junk box.)
- caesar
- Has thanked: 183 times
- Been thanked: 174 times
Re: Airtronics 94156 servo info?
Hi,
The 94156 server is listed as a recommended servo in the T2 manual, so must be period correct. I'll try find the specs for you.
I couldn't find anything on the 94156 but it uses the same gear set as the 94158, might be similar spec to the 94158
94158 spec size=1.54 x .79 x 1.48 weight=2.10 speed= .09 sec/60°torque=130 oz-in bearing =Double
Looks to have been made around mid 90s
cheers
Rob
cheers
Rob
Believe this replaced the 94151 (Airtronics high speed servo). I had the 151 in my XX-T and I think it was a year or two old at that point; I believe it came out around '93-94. I guess '95-96 on the 156 but that's just a guess.
- 1868 Views
Last post by slvrback
- 510 Views
Last post by bluewormx
- 1480 Views
Last post by prp
- 26 Replies
- 2045 Views
Last post by a01butal
- 916 Views
Last post by AndrewSi
- 906 Views
Last post by SmallScaleSmitty
- 1494 Views
Last post by drbelleville
- 1773 Views
Last post by surgetek
Users browsing this forum: Tbot [Bot] and 8 guests
