Indoor, on-road track surface?
- SMOKE-DOG
I've been contemplating making a small 1/12 scale on-road track in my basement. I've got plenty of room for a small track with 4' wide lanes. My basement floor is concrete and I don't wanna spend too much $ on carpet so I was thinking about painting my basement floor with high-grip floor paint. I've found a few at Lowe's but was wondering if anyone had any suggestions of paint on another low cost solution.
TC showroom: http://tamiyaclub.com/showroom.asp?id=18447
- Charlie don't surf
- Has thanked: 355 times
- Been thanked: 470 times
Re: Indoor, on-road track surface?
I have ran on concrete painted with that traction paint, its hell on tires but not bad at all-
- Been thanked: 4 times
Rubberised driveway sealer is what we used years ago.Just clean the concrete maticulously let dry then apply where you want and let dry.DON
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
We used roofing felt paper to make a track in a mall one time. It worked pretty well, but it didn't hold up too well with all the turn marshal activity. Other solutions are better I'm sure, but this could be the cheapest way if you just wanted to give the track a trial run.
- SMOKE-DOG
Cool... I'm bout to get started soon. I do have 1 long gap in the floor where the concrete seperates. Any ideas on filling that first? I did run a car over it and you can't even tell it's there but I'd like to fill it anyway if there is a quick fix for it.
quick crete has a hole host of stuff. Look under patch crete ,some of there stuff is self leveling but that does not mean that you will not have to get down and tool it . If it is too big of a gap then Use concrete or shink grout ,and a acrilic additiveSMOKE-DOG wrote:Cool... I'm bout to get started soon. I do have 1 long gap in the floor where the concrete seperates. Any ideas on filling that first? I did run a car over it and you can't even tell it's there but I'd like to fill it anyway if there is a quick fix for it.
The onroad track in Shreveport was once a skating rink and they coated it with an asphalt roof sealant. I don't know if it would stick to the concrete though...
As for the expansion joint in your floor, I'd definitely use something that is pliable so that it doesn't defeat the purpose of that joint
Allen
Allen
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
If you buy the white elastometric roof sealant its not bad either. By the 5 gal. buckets its around $70 near me. Dries to a rubber like surface that would stick good and brightens up a basement
you could tennis court paint. lowes sells it i think they call it "skid not". i was told this is what is used alot in the uk when they run on converted wharehouse floors. i found it on schumacher's uk forum when Birdsboro was looking for new paint but it was really expensive.
- SMOKE-DOG
Tennis court paint?
Hmmm... Ima check into that.
do you really want some kind of paint on there? i mean i'm not sure i'd want to do that to my basement.
i'd check the carpeting stores for 1/2 a roll of something, like a remnent.
- SMOKE-DOG
Yup. The cement floor is already painted gray. And other than the tennis court paint, the paint I was looking at using is high grip floor paint made for cement floors. It's an unfinished basement and my man-cave with nothing down there but my stuff and my workshop. Besides, the wife gave the OK multiple times so... I'm good!kaiser wrote:do you really want some kind of paint on there? i mean i'm not sure i'd want to do that to my basement.
I did a job 2 years ago were we put in a tennis court. The 'paint ' that we used had ground silicon and latex added to a acrilic paint, cool stuff butt $$$. If the paint on the floor now is not epoxy and you use a 2 part garage floor paint you will have a mess.
- 580 Views
Last post by Frankentruck
- 33 Replies
- 4081 Views
Last post by askbob
- 3101 Views
- 1801 Views
Last post by MOmo
- 917 Views
Last post by fredswain
- 1899 Views
Last post by DaveM
- 1511 Views
Last post by Seabass
- 1512 Views
Last post by kaiser
Users browsing this forum: Semrush [Bot] and 2 guests
