servo saver big brute
Hello, does anyone know of a good servo saver to use on the kyosho big brute? the original does not work with my hitec servo.
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
Re: servo saver big brute
Kimbrough unit specific for Hitec servo output gear. Choose one that is fit for the servo and the application.
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
I have no idea, but if that's the case, maybe it's easier to replace the whole servo by one from Futaba or something...
- highwayracer
- Been thanked: 6 times
Yes it is. The car crusher series uses a rac and pinion type of setup. There's a slot on the rack....and then a long screw with spacers is bolted on to the lower hole of the stock servo saver.RichieRich wrote:Isn't the servo saver some sort of weird contraption for the Big Brute?
I think you'll have to move the servo forward if you'll be using a kimbrough.
hope this helps...
I get the steering to work to a certain extent using the circular servo horn without the spacer, but will sometimes rotate out of the slot the screw goes into.
- Been thanked: 325 times
Sounds like the plastic gear on the servo might be stripped?lebowski770 wrote:I get the steering to work to a certain extent using the circular servo horn without the spacer, but will sometimes rotate out of the slot the screw goes into.
I finally got it using the oval shaped servo horn. although the screw that goes into the slot bar is not even a quarter of the way in it works for now.
Coelacanth wrote:Sounds like the plastic gear on the servo might be stripped?lebowski770 wrote:I get the steering to work to a certain extent using the circular servo horn without the spacer, but will sometimes rotate out of the slot the screw goes into.
Oh no I was referring to the slot of the big brute steering block mechanism
- 825 Views
Last post by SmallScaleSmitty
- 1120 Views
- 1938 Views
Last post by Phin
- 858 Views
Last post by Lonestar
- 549 Views
Last post by badhoopty
- 908 Views
Last post by PBR Allstar
- 525 Views
Last post by Dangeruss
- 958 Views
Last post by RCveteran
