Problems with tranny or spur gear need help
Ok got everything fixed on my rc10t1 and now its doing something nasty...it slips i can lightly place my foot eith on or in front of it and just the spur and the shaft it is mounted to the things the dogbones set in dont i move my foot and it slipps bad and slowy takes off and builds speed..i have tightened the little nut and tightened and loosened the things the dogbones sit in...nothing seems to fix it...ne suggestions other then buying a new1...im poor althe time do to bills...rather fix it if i can
- Has thanked: 7 times
- Been thanked: 42 times
Re: Problems with tranny or spur gear need help
Is there any loud, crunching noise coming from the truck when it's slipping or is it pretty quiet?
Make sure you don't have any oil or grease on the slipper pad, if that's dirty it won't function properly. I would also rebuild your differential just to be sure it's working correctly. Also check both the slipper spring and diff spring. If either of these is worn out (not crating enough tension) then neither of those assemblies will function correctly.
Yes there is a loud noise from it..i only have 1 spring for the spur bolt to hold the spur on..where does the other spring go.my truck is electric...
Ok, if it's making a loud noise, it's the differential. There's a spring in there too. I would do a search for an assembly manual and rebuild the transmission. It sounds like your differential is loose.
Its defenitly the diff set up..i took it apart to rebuild it i found the spring it was stuck in the right side now when i slowly pulled the bolt out from the left side i waited to see the light bearings there was only 2 and those got lost due to the bolt and washers were dry not a speck of grease on it...i have a manual for the tranny now my question is do they sell whole trannys for the rc10t1 with all metal gears if not how about a good diff set.a website would be best there isnt many hobby stores here and the ones that r are too far to go to
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Rc10tdriver wrote:Its defenitly the diff set up..i took it apart to rebuild it i found the spring it was stuck in the right side now when i slowly pulled the bolt out from the left side i waited to see the light bearings there was only 2 and those got lost due to the bolt and washers were dry not a speck of grease on it...i have a manual for the tranny now my question is do they sell whole trannys for the rc10t1 with all metal gears if not how about a good diff set.a website would be best there isnt many hobby stores here and the ones that r are too far to go to
if you have the instructions and hence part numbers, then all you have to do is reorder new parts to replace those worn out or lost. Tower Hobbies is the best source for "older" rc10 parts
why the heck would you want an all-metal gear set? The 2.25 stealth is one of the best ever done in stock form. replace what's needed and start again!
Paul
Paul
- 1654 Views
Last post by smahoney1
- 1322 Views
Last post by binjaloo
- 1356 Views
Last post by jackflak
- 2556 Views
Last post by JK Racing
- 802 Views
Last post by shredderboy
- 1763 Views
Last post by superfly
- 1735 Views
Last post by knucklebuster
- 1119 Views
Last post by Chemical
Users browsing this forum: Ahrefs [Bot] and 19 guests
