What size pinion gear and spur gear?
mikea96
Has thanked: 596 times
Been thanked: 856 times
Post by mikea96 »
So what size pinion and spur should i run in my gold pan buggy with stealth tranny and a Reedy Sonic 13.5 brushless?
TitleSeventeen
Re: What size pinion gear and spur gear?
Post by TitleSeventeen »
All I know is the stock pinion calls for a 48p, 21tooth for the stealth cars, I went with that for a starting point.
Has thanked: 215 times
Been thanked: 310 times
mikea96 wrote:So what size pinion and spur should i run in my gold pan buggy with stealth tranny and a Reedy Sonic 13.5 brushless?
Miles is running a 72/28 with his 13.5 running no boost- 5 min qualifiers are coming off at 150f
mikea96
Post by mikea96 »
Ok so i shouldnt start with the 81 tooth spur on it?
You can, but you can't get enough gear on the pinion to get any punch
mikea96
Post by mikea96 »
Ok thanks!
JK Racing
Has thanked: 128 times
Been thanked: 242 times
Post by JK Racing »
No boost 17.5 I was running 33/69 :)
No boost 13.5 I would drop about 4-5 teeth (so 28-29)...same range that Reggie said.
