Old radio and reciver problems
Rc10tdriver
Post by Rc10tdriver »
Hello all i have a old hitec sport lynx controller that the trigger came off of...well i fixed it and it works only problem is my truck goes but stops at about 2 feet i have to follow it as if its a old tyco car hahaha..other then getting a new spektrum which i cant afford with bills always needing payed is there a way to fix the range...the anntena wire from the box is about 7 inches maybe six....ne help would be nice thank you for ur guyses time
slotcarrod
Been thanked: 45 times
Re: Old radio and reciver problems
Post by slotcarrod »
Open up the cases and make sure the circuit boards or solder joints for the antennas are ok in both the rx and tx. It could also be bad crystals.
Rc10tdriver
Everything looks good on both circuit boards...so im going to try need crystals when i can get some extra money maybe monday..if its not bad crystals is there ne otherway to fix or find out a problem?or would it be better to just get a new radio
klavy69
Moderator
Has thanked: 628 times
Been thanked: 294 times
Post by klavy69 »
Rc10tdriver wrote: be better to just get a new radio
you can pick up one of the flysky cheapo 2.4 radios for about $25-$30 shipped and just be done with it. Unless you have some nostalgia issues with the one you are trying to troubleshoot that is. Otherwise you'll end up doing that and spending cash on a new set of crystals...
rhino1
Post by rhino1 »
Has your antenna from your receiver been cut? 6 or 7'' seems a little short.
Those are my toys and no I will not share!
Rc10tdriver
I havent cut it the crystals r about 4 years old....scenario is was working at this place my buddy got my into rc alittle and a guy from work had some old stuff told me 60 bucks its urs and gaqve me this box i tryed to pay him but he quit his job before my first payyday he only got 25 bucks....contents of said box was a tc3 missing a few essential parts...a rc10t1 alumminum chassis all the arms and turmbucks and wheels just needed a motor esc servo batt.a hitec rx and tx was in the box so i got5 the essential 0parts for the tc3(thats wat i was raceing well turing class)put the rx in and it was a fast as car..i had the novak gtx esc with a reedy modified ultra series brushes...for my first real rc that was nice...i got a tc4 with a diff rx and tx so old faithful got put up...been up ever since and that was 2007.
slotcarrod
rhino1 wrote:Has your antenna from your receiver been cut? 6 or 7'' seems a little short.
This is true. Should be 12-16 inches, even more if it's a very old rx!
Rc10tdriver
Ok i mesures the wire there is 10.2in of wire on the rx ive fixed the trigger nnow i dont know wats rong...would it be do to my aluminum tub style chassis....if it is would a 2.4ghz have less radio interfirance the a standard am crystle tx?
rhino1
Post by rhino1 »
What kind of motor are you using? I guess if you were using to much motor than your speedcontrol is rated for you may not be getting the 6 volts to operate your reciever properly. because of the amount of drain the motor is pulling from your batteries.
Rc10tdriver
Hahaha this makes me feel slightly retarted....yes i ws running 2 big of a motor...my truck has my old evader sprint 2 speedo i put a 17turn reedy radon 30000rmp to it the speedo goes down to a 20t u can use a 19t but its advised to get a fan set up for the esc and motor..i have the origanal sprint2 phantum 2 motor its a 20t guess ill put it back on till i get one of these 27t roar motors to work.realy want to start raceing again.
