F150 problems
rhino1
F150 problems
Post by rhino1 »
I have 2000 F150 4x4 That I have had since new with 250,000 wopping miles on it. Today on my way home the heater core went bad. So I thought no big deal I'll bypass it for the time being so I did. So I put antifreeze in it and go down the road and it overheats. The thermastat Was bad to, So I go get one now it no longer overheats but now it runs real ruff. Most likely from it overheating. It was not hot for more than 2or3 blocks at the most. Any ideas other than the heads or head gaskets before I throw away needless money at it
Those are my toys and no I will not share!
THUNDERSTRIKE1
Re: F150 problems
Post by THUNDERSTRIKE1 »
Do a compression check on each cylinder.Some times when overheat it you cook the oil off the rings,sometimes just need pour oil in each cylinder and bump it over a few times but not crank it yet til done.But first check compression.That many miles more than likely the gaskets.But try this first may save you in long run.You could possibly use marvel mystery oil in cylinders.DON
rhino1
Re: F150 problems
Post by rhino1 »
Those plugs on the f150 can be such a pain in arse to get out with out breaking them but i'll try it. I would love to buy a new truck but its been the best vehicle I have ever owned.
illshou
Re: F150 problems
Post by illshou »
the ruff running may be due to a overlooked vacume line or sensor not hooked back up properly when yor reassembled it after the t-stat. Possibly the mass air flow sensor. Head gaskets are pretty common to go bad in thoes engines after a overheating. With that many miles it may be better off to put a used engine in because if you do the top end on such a high millage one i've seen the bottom end go bad right after.
Easiest way to do heads or even replace the motor is to lift the cab off the truck first, makes life way easier.
Mazdaj
Re: F150 problems
Post by Mazdaj »
What size motor? Individual coil on plug set up? I remember same era Ford products with the V8 used to leak coolant onto rear coils on passenger side-right under heater core. Maybe some got on them?
rc10johnny
Re: F150 problems
Post by rc10johnny »
Reset the computer,take the pos cable off for three mins,see if it resets....JohnnySr
Orange
Re: F150 problems
Post by Orange »
Good luck not breaking any of those plugs. they are a pain and not cheap to replace!
Sean Sanchez
Gallery:
My feedback
illshou
Re: F150 problems
Post by illshou »
the earlyer f150's dont have nearly the trouble with breaking plugs that the newer ones with the 3v v8 have. I avoid them like the plague.....
fordtransman
Re: F150 problems
Post by fordtransman »
The 5.4 3v you have to worry about breaking plugs. The earlier modulars you have to worry about taking out the threads from the head.
rhino1
Re: F150 problems
Post by rhino1 »
fordtransman wrote:The 5.4 3v you have to worry about breaking plugs. The earlier modulars you have to worry about taking out the threads from the head.
Thats what I'm worried about It has the 4.6. If the head gaskets I would hate to just rebuild the top end and not the bottom end with 250,000 miles on it. I might as well have the whole engine rebuilt.
illshou
Re: F150 problems
Post by illshou »
Unless you have the special ford tool for pulling out the broken parts.....
Halgar
Has thanked: 146 times
Been thanked: 197 times
Re: F150 problems
Post by Halgar »
illshou wrote:Unless you have the special ford tool for pulling out the broken parts.....
Like the Al-Jon LC90? :mrgreen:
cautrell05
Re: F150 problems
Post by cautrell05 »
Would have made more sense to use a proper plug to begin with. Glad I work in a GM dealership and not a ford one. I have to give alot of credit to the Ford techs. You have to be dedicated to work on those all day. I have been with gm for 10 years now. I would have quit long ago if I had to work on fords.
Nick
Orange
Re: F150 problems
Post by Orange »
I hear Ford techs saying the same thing about GM's... Whats funnier is that I hear Chrysler techs saying the same thing about GM's too, LOL Must be a trend, :)
Sean Sanchez
Gallery:
My feedback
Has thanked: 356 times
Been thanked: 470 times
Re: F150 problems
Orange wrote:I hear Ford techs saying the same thing about GM's... Whats funnier is that I hear Chrysler techs saying the same thing about GM's too, LOL Must be a trend, :)
Any any one tech that can wrench one brand, can do another- unless it's a german car
Users browsing this forum: No User AvatarBing [Bot] and 6 guests
